Page 1 of 3 1 2 3
Hemi street solid roller #1580699
02/18/14 10:54 AM
02/18/14 10:54 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys Im curious; after some bench racing with a buddy, Im curious on the cam/specs you run on Hemi solid rollers for reliable street use?
Mine is a 572 with 11:1 oiling thru the deck with Indy heads and Stage V rollers - our premium pump gas is good here. Just wondering what you've all used specs wise ie: lobes/springs etc are for a lower maintenance street solid roller ?
Thanks !
Re: Hemi street solid roller [Re: LAD 524] #1580700
02/18/14 11:21 AM
02/18/14 11:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm running a comp cams 588 solid roller in my 440-6 (11.2:1), you have a ton more motor but this thing has been together for a while w/ no issues and I hardly ever have to touch the valves. I'm guessing you'd be using a much bigger bump stick which may be harder on the valve train.
Coming soon!!!!
Re: Hemi street solid roller [Re: Mr.Yuck] #1580701
02/18/14 11:39 AM
02/18/14 11:39 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Yep you guessed right - our bench session was based on adding some street reliability/margin of "safety" later in the piece
Bump
Re: Hemi street solid roller [Re: LAD 524] #1580702
02/18/14 12:09 PM
02/18/14 12:09 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
For street, staying around or a little below .650 seems to be the ticket. When I exceed that amount, I go thru a lot more parts. If I were to do it again, I would go with Barton T&D valve train and let it really live, but my Indy heads do not allow for their use on my current engine.
For a 572 to really live, you will want the Barton T&D or some kind of extra oiling up top on both the springs and the push rod tips. And make sure you use lash caps...Ask me how I know!
Re: Hemi street solid roller [Re: LAD 524] #1580703
02/18/14 12:34 PM
02/18/14 12:34 PM
an8sec70cuda Offline
I'm sure I've told you my cam specs before, but here you go...
.672"/.651" lift
276°/284° at .050"
112 LSA
Comp 943 springs...225 psi on the seat, 600 psi open.
DLI roller rockers.
Been using this same setup since 2006. Mild setup that's eally easy on parts, but makes good power.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi street solid roller [Re: LAD 524] #1580704
02/18/14 01:08 PM
02/18/14 01:08 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I'ld call Rich Nedbal and let him spec your cam. Not too many guys have his amount of experience with your kind of combo.
Master, again and still
Re: Hemi street solid roller [Re: DaveRS23] #1580705
02/18/14 03:58 PM
02/18/14 03:58 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
10.4-1 605 street Hemi. Bullet custom solid roller. .767/.676 288/292@.050 113C. Comp Cams 829 lifters, K-motion K-950 springs 245/720. Rebuilt and blueprinted stock widepad rockers. Engine peak hp is at 5800rpm so the motor doesn't get twisted to high. About 2000 street miles on it no problems so far.Dave
Re: Hemi street solid roller [Re: quickd100] #1580706
02/18/14 04:14 PM
02/18/14 04:14 PM
And what did you do to the valve train to make it live I wonder? My little .750 lift cam ate everything...You put enough street miles on that baby, and you will see. I spet $2k refurbing my heads and dropped a little .588 lift cam in. Not happy with the loss in power, but I hit a wall with mine above .650"...
Re: Hemi street solid roller [Re: Dragula] #1580707
02/18/14 04:26 PM
02/18/14 04:26 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Randy; I'm not saying I won't have a problem, but so far so good. I'll be pulling the motor down in a few weeks to check it over again and to install a geardrive. With minimal V/P clearance and .060 cam lobe to rod clearance I've had a few sleepless nites thinking about the timing chain. Dave
Re: Hemi street solid roller [Re: LAD 524] #1580708
02/18/14 06:14 PM
02/18/14 06:14 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Thanks !
The key to making a HEMI solid roller live on the street is to get oil to the pushrod cups. That's why I always use oil-through-the-pushrod style lifters. I suggest Crane in my book. Use through-the-shaft oiling for the rocker bushings and everything will be happy. Also keeping the lift under .700 (with plenty of coil bind clearance), will keep the springs cool enough.
Re: Hemi street solid roller [Re: Mopar_Rich] #1580709
02/18/14 09:12 PM
02/18/14 09:12 PM
pa
572charger Offline
572charger  Offline
pa
t-d raybarton rockers 282/291 at .050 720/690 lift at the valvein my 606 cube hemi comp 829s and 943 springs in at 245 lbs on the seat 600 open ,i change the springs and lifters every 3-4 yrs depending on milage my rockers and pushrods are 11 yrs old never a problem
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi street solid roller [Re: Mopar_Rich] #1580710
02/18/14 09:32 PM
02/18/14 09:32 PM
Thanks !
Rich,
Do you oil thru the intake and exhaust or just the intake? What is your oil pressure drop doing this? Been thinking of going back to a mid .650 roller and this is where I need to know a few things. Do you restrict any oil to the heads when you do that?
Re: Hemi street solid roller [Re: Dragula] #1580711
02/18/14 10:16 PM
02/18/14 10:16 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Thanks !
Rich,
I too, would appreciate any info on this subject. I am planning this same kind of street combo soon and would like to have the valve train live.
So how about it Rich, care to spill the beans on this?
Thanks!
Re: Hemi street solid roller [Re: DaveRS23] #1580712
02/19/14 01:06 AM
02/19/14 01:06 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Thanks!
Beans have already been spilled :^) I run the same lifters in both intake and exhaust with Smith Bros thick wall pushrods. I use bronze bushings in the lifter bores with fairly small holes in the bushings (.022 +/-), "white glove" cleaning and assembly, and a low lash cam with street ramp lobes. The effect on the oil pressure is minimal as long as you use a high volume oil pump and good oil (I use Amsoil). I have solid roller HEMIs on the street for thousands of miles and one blown HEMI that has crossed the USA several times The intermediate shaft gear will wear far before valve train issues.
I cannot over emphasize the importance of setting the installed height correctly so the springs never approach coil bind. Most people do not realize that the springs start generating heat well before they bind.
Hope this helps...
Re: Hemi street solid roller [Re: Mopar_Rich] #1580713
02/19/14 01:18 AM
02/19/14 01:18 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Thank you for sharing!
Re: Hemi street solid roller [Re: DaveRS23] #1580714
02/19/14 10:15 AM
02/19/14 10:15 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Great info guys - Chip yes Ive seen your spex thanx for sharing once again.
Rich - I'lll post up my cam/spring combo shortly for your thoughts/comments as to how you see it panning out.
I asked the guys at Bullet for the cams lobes not to be too aggressive as the car is primarily a street car which which see some track time.
Specs coming....
Re: Hemi street solid roller [Re: LAD 524] #1580715
02/19/14 11:10 AM
02/19/14 11:10 AM
BTW...I do not have pushrod oiling and don't even have lifter oil galleys in my block (KB).
I've freshened the motor up twice since 2006. Put new valve springs on both times just for peace of mind. Sent the lifters back to Isky and they haven't needed a thing yet.
CHIP
Re: Hemi street solid roller [Re: Mopar_Rich] #1580716
02/19/14 11:54 AM
02/19/14 11:54 AM
Thanks!
Hope this helps...
So you use bronze guides in the lifter bores to restrict the oil flow to the oil thru lifter, correct?...Wonder what that little operation costs. Would not just switching to the oil feed lifters work?
Re: Hemi street solid roller [Re: LAD 524] #1580717
02/19/14 12:54 PM
02/19/14 12:54 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
My 572 is 10.5-1.
Comp cams
.421 lobe lift
Stage V rockers
.674 I .657 E
264* 270* @ .050
112 LSA
Lifters have Oil fed rollers, but not push-rod oiling.
Smith Bros PRs
Comp 943 springs
World alum block comes bushed with oil hole.
I do not have a lot of street miles on the engine yet, and only a few passes 1/8th mile.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi street solid roller [Re: Hemi Allstate] #1580718
02/19/14 01:19 PM
02/19/14 01:19 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My 572 is 10.5-1.
Comp cams
.421 lobe lift
Stage V rockers
.674 I .657 E
264* 270* @ .050
112 LSA
Smith Bros PRs
Comp 943 springs
Any idea what size the lifter bushing oil hole is?
Page 1 of 3 1 2 3
