Dash clearance with replacement speakers
#1579821
02/16/14 03:47 PM
02/16/14 03:47 PM
Posts: 378 Troy, TX
74Sport
Troy, TX
Although I do make and sell brackets to allow you to install two dash speakers in place of the OEM single speaker, this is not a "FOR SALE" ad. I intend for this thread to be used for a discussion of the problems encountered and the solutions found for particular speaker installation issues.
If there's a bracket modification I can make to avoid the problems, I am more than happy to do so. If it's a matter of speaker design and choice, there's not much I can do, other than refer you to those who have successfully worked around the issues.
Let the discussion begin...
There's a difference between ignorance and stupidity.
Ignorance is not knowing any better.
Stupidity is knowing, yet doing it anyway.
Re: Dash clearance with replacement speakers
[Re: 74Sport]
#1579822
02/16/14 04:31 PM
02/16/14 04:31 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
I used your bracket with Kicker KS35 speakers in my 1969 Barracuda. I had to add thick weatherstrip to the bracket to space it down a bit. But overall it fit great, and sounds much better than stock.
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: 74Sport]
#1579825
02/16/14 06:02 PM
02/16/14 06:02 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Jerry.. There are a couple of variables to consider that directly affects its height and clearance.. 1. The brand of speaker, some are deeper than others due to magnet size 2. The speaker can be mounted from the top or the bottom, again depends upon selected speaker brand The use of foam tape is interesting for sealing the speakers/mounting plate to the dash but again the variable factor is how much clearance is available under neath the dash.. Just my $0.05...
[Re: Sinitro]
#1579829
02/18/14 05:48 PM
02/18/14 05:48 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Just my $0.05...
and to further this along - Jerry, if you over cut the speaker holes instead of making them an exact fit. guys, when you drill the holes in the bracket to mount the speaker, over size the holes. this will give you some wiggle room when you button everything up. and the foam tape idea is perfect to lower the bracket for dash clearance.
[Re: 74Sport]
#1579830
02/19/14 02:40 AM
02/19/14 02:40 AM
Posts: 378 Troy, TX
74Sport
Troy, TX
My first bracket design was for my son's '74 Dart Sport to add a pair of Volfenhag 3.5" two-way speakers. Those speakers have two features going for them. A built-in raised ring allows the speaker to mount flush to the bracket's bottom surface without making contact with the flexible rubber surround. They also have low-profile center tweeter cones which avoid making contact with the underside of the dash grill. This all makes for a very compact installation. Of course, this was in an A-body dash with plenty of room below.
If clearance is limited in your particular case, top mounting your speakers through the bracket openings would gain you approximately 0.080", the material thickness. Slipping washers or thin spacers between the bracket and speaker mounting flanges could provide a little more lift, but the limiting factor then becomes available clearance above the center cone.
Choosing the right speaker is critical.
[Re: a12rag]
#1579831
02/19/14 07:41 AM
02/19/14 07:41 AM
Posts: 25 Groningen, the Netherlands
4doorSatellite
with it being an A/C car (yes I put it all back and it operates), the heater controls and vacuum lines did not have enough room for the double speaker
I made my own bracket with 4'' speakers, put the speakers as close together as possible and a little offset to the front.
68 Satellite with A/C.
