Hughes 5660 cam #157921
11/27/08 10:43 PM
11/27/08 10:43 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
I have read that a solid cam will act 10* smaller in duration compared to hydraulic. My old 484 seemed a little tame ~242*@.050. The Hughes solid is 256*/260*@.050, or act like a 246*/250* hydraulic. Am I looking at this right, or do I have it bass ackwards?
Re: Hughes 5660 cam [Re: momopar] #157922
11/28/08 09:03 PM
11/28/08 09:03 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
That is about right for a .020 lash solid cam.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Hughes 5660 cam [Re: Rapid340] #157923
11/28/08 11:45 PM
11/28/08 11:45 PM
IN
ahy Offline
ahy  Offline
IN
For duration measured at .050 I understand that a mechanical would have a wider RPM range compared to a hydraulic with the same duration. The mechanical works like a slightly smaller hydraulic at lower RPM and works like a slightly bigger hydraulic at higher RPM. I took a look at Hughes web site and the 5660 mechanical lists an operating range from 2800-6600. The nearest hydraulic is the 5561 which shows an operating range from 3200-6200. The mechanical has a little more down low AND at the top end compared to the hydraulic.
