2005 Magnum blower motor #1579108
02/14/14 09:25 PM
02/14/14 09:25 PM
Canada
WO23Coronet Offline OP
Canada
I have a 2005 Magnum RT and the blower motor stopped working. It has absolutely nothing on any of the settings so I'm thinking its the motor itself and not the resistor card. If it makes a difference it has the dual climate option and the auto control option. Any input?
Re: 2005 Magnum blower motor [Re: WO23Coronet] #1579109
02/14/14 11:17 PM
02/14/14 11:17 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Not the same era, but I had a '95 Dakota, blower stopped working completely as yours. Blower resistor coils were good. On the Dak, the blower was under the passenger dash. I pulled it apart enough that I could see it in action (or inaction). With the switch on, I gave the squirrel cage a little bit of a manual spin, then the motor gradually picked up speed and worked. It was lazy (dry). Gave the blower motor shafts a squirt of oil, and the motor worked freely on its own after that, no further work required.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
