Cams #1578825
02/14/14 08:46 AM
02/14/14 08:46 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I'v seen seen the tread on here bout "Help me pick a cam for my 511"and had me thinking whats the biggest cam have someone has use in a stock block?And i no it's has alot to do with combos,did not what to get into that,just what to hear what size have uall used in a stock block i did not what to hi-jack the other thread with this ? so thought i'll start a new one............Tha
P.S i filled out the cam questionear with Bullet cam and they recommendation the they gave me were pretty close to what i have
Re: Cams [Re: racerx] #1578826
02/14/14 12:56 PM
02/14/14 12:56 PM
gregsdart Offline
gregsdart  Offline
The lobe lift is limited to about .515 or so, and the next thing is cam core flex, which limits the rate of lift along with limited lobe profiles. Duration isn't limited, so you can go way too far with that. I don't know just how much the cam core flex and twist affects the motor, but I am sure it is quite measurable. The gen III Hemi has a very large cam core to allow high rates of lift with limited duration, and may also be bigger to offset cam twist. This brings up the question, best answered by cam engineers, of how much different installed centerline the bigger cam cores need to address cam twist in the older cam core size. If it is significant, then there is the answer. That would be compensation for cam twist.
Re: Cams [Re: racerx] #1578827
02/14/14 01:11 PM
02/14/14 01:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm running a .640/.640 lift in my 416 in the Rampage
its not the limit by far
EDIT
with 1.5 ratio rockers
Re: Cams [Re: MR_P_BODY] #1578828
02/14/14 01:17 PM
02/14/14 01:17 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I am assuming they are talking before the ratio of the rocker arm adding in there. Not total lift, just at the cam.
Re: Cams [Re: Dodgeguy101] #1578829
02/14/14 01:25 PM
02/14/14 01:25 PM
gregsdart Offline
gregsdart  Offline
Yep, just cam lift. That is where BBC motors have a slight edge, they come with 1.7 ratio rockers stock. We are stuck with 1.5, which adds to the total weight the springs need to control .
Re: Cams [Re: gregsdart] #1578830
02/14/14 01:51 PM
02/14/14 01:51 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Back in the 70's and early 80's the R286 cam (750 lift) was VERY popular. Most of use ran them on .030 over 440 engine with TRW pistons, stock rods, and stock cranks. My Duster ran a 9.81 with one and I still have 3 of them sitting on a shelf.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cams [Re: pittsburghracer] #1578831
02/14/14 01:55 PM
02/14/14 01:55 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
How high did you guys spin those .030 440's? Do you know the duration @.050?
Sincerely,
GIT (gearhead in training)
Re: Cams [Re: Jeremiah] #1578832
02/14/14 01:59 PM
02/14/14 01:59 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
The biggest cam I have run is .475" lobe 308*@0.050"
I believe cam size is duration not lift but to each their own.
Re: Cams [Re: Jeremiah] #1578833
02/14/14 02:03 PM
02/14/14 02:03 PM
PA.
"Little"John
"Little"John
PA.
Sincerely,
The 286 is at .050 and pretty sure 332 total rings a bell. I ran a 14-31 Goodyear slick with 4.56 gears shifting at 6800. Direct Connection rod bolts, shot peened rods, with polished beems.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cams [Re: pittsburghracer] #1578834
02/14/14 02:28 PM
02/14/14 02:28 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
810/775 for me,with 1.7 rockers,that translates into 476/455 actual lobe lift.but I know there are others running higher actual lobe lift,i have no idea what the max limit is,or the amount of twist and flex,i guess some of that would be determined by cam core quality and hardness.i am sure some cam companys test this and require at least a specific core hardness,also as lift increases,so should the base circle,but I am sure theres a point of no return here,without the proper supporting equipment for extreme lifts,head flow,cubic inches,geometry,etc,you will just be wizzing in the wind,matched combination makes power.in my years I have seen way too many over cammed combinations,killing power and torque,i believe the largest cam listed in the bullet catalogue is 510 lobe lift,thats 867 w/1.7 rockers........I would like to know the outcome of this myself..........
SFI 25.5 depends,no leak,even at 213 mph....
Re: Cams [Re: dakotawilly] #1578835
02/14/14 02:51 PM
02/14/14 02:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How would the base increase if the lift increases...
the limiting factor on lift is the came tunnel..
(you cant get the cam in the tunnel if the lobes were
to start out larger than the tunnel) then they grind
from there... more lift they cut more out of the base
Re: Cams [Re: MR_P_BODY] #1578836
02/14/14 03:01 PM
02/14/14 03:01 PM
dakotawilly Offline
dakotawilly  Offline
to a point yes,you are correct,but the smaller the base circle,the more viscious lift and control at rpm becomes,ramp design,you can increase the base circle some,but not a huge amount for sure.once again theres a point of no return..its give and take for sure.......
Re: Cams [Re: dakotawilly] #1578837
02/15/14 01:53 AM
02/15/14 01:53 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Hmm....so is all this with a stock block?
Re: Cams [Re: gregsdart] #1578838
02/15/14 02:06 AM
02/15/14 02:06 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
So help me understand this,you're saying that an 1.5 is heavier than a 1.7?I know that the 1.7 adds to the lift.
One reason i bring this cam ? up is that generaly GM blocks seems to run much bigger cams than crylers.Do they use a bigger bearing jounal than us crysler guys to help support the cam flex?
Re: Cams [Re: racerx] #1578839
02/15/14 02:15 AM
02/15/14 02:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know about the journal size but stock they
run a bigger ratio rocker so they dont have to have
the base ground down smaller which helps with rigidity
Re: Cams [Re: racerx] #1578840
02/15/14 03:03 AM
02/15/14 03:03 AM
gregsdart Offline
gregsdart  Offline
The higher the rocker ratio, the less movement of the rockers and pushrods for a certain lift, which makes it easier on the springs. As Iunderstand it Mopar lifters are bigger, which allows a bigger roller wheel, which helps a touch for rate of lift.
Re: Cams [Re: gregsdart] #1578841
02/15/14 11:40 AM
02/15/14 11:40 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Okay i see,so both brands have there advantages to a degree Hummm...Thaxs fellas
Re: Cams [Re: racerx] #1578842
02/15/14 03:28 PM
02/15/14 03:28 PM
dakotawilly Offline
dakotawilly  Offline
i am sure there is something to that,pro stock guys are well over an inch of lift ,but,they use a cam bearing for every pair of lobes,9 to be exact,,and their cam bearings I believe are 70-75 mm,HUGE,by any standards.where and when the actual flex comes into play would vary by combination of valve springs,rocker ratio,rpm,and such.us "normal" racers aren't looking for every ounce of horsepower at any cost either.i guess the best scenario would always be run what the manufacturer recommends and forget it.their history and r&d wouldn't lead you astray for sure,their reputation depends on it...........
Re: Cams [Re: racerx] #1578843
02/16/14 10:08 PM
02/16/14 10:08 PM
Southern IL.
jafr Offline
jafr  Offline
Southern IL.
If you are referring to a big block Chevy, there is a big difference in port volume and shape as compared to a big block Wedge headed Chrysler. You could run a cam grind designed for a Chevy but it would not perform as well as a grind designed for a Chrysler.
A big Chrysler has a factory .904 lifter which is larger than a Big Chevy. Having the bigger lifter lets you have a faster ramp speed on the camshaft without destroying the cam lobe or the lifter. Most aftermarket Chevy blocks come with a .904 lifter bore.
