Need a battery tray for a Challenger #1578772
02/14/14 12:16 AM
02/14/14 12:16 AM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Mayby I asked this in the wrong forum before. I'm replacing the trunk mount battery with an under-hood set-up. Original has been gone for many years. Who has the most accurate reproduction? This is on a 70 Challenger R/T Convertable, so it's important to be accurate. -Pat
Re: Need a battery tray for a Challenger [Re: Carsavior] #1578773
02/14/14 07:14 PM
02/14/14 07:14 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
There are a lot out there. AMD (Stephen's Performance, etc.) has them, as well as a number of others. I believe they are all the same.
It was an item that Mopar continued to make so there are a lot around.
To the very discerning eye there is a slight difference from the originals, but once you lay a battery on it you can't see it anyways.
Re: Need a battery tray for a Challenger [Re: RP's R/T's] #1578774
02/14/14 11:58 PM
02/14/14 11:58 PM
Monroe, LA USA
Monroe, LA USA
Saw some from at least two different manufacturers. Just didn't want one that was cheaply made or too thin. Saw AMD and Goodmark.
Re: Need a battery tray for a Challenger [Re: Carsavior] #1578775
02/15/14 02:29 PM
02/15/14 02:29 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
There are at least 2 different OEM stampings.
One may be 70 only?
NS1AAR
