e body and b body #1578765
02/13/14 11:38 PM
02/13/14 11:38 PM
Aubrey, Texas
O
oldtimer5151 Offline OP
O
Aubrey, Texas
What is the difference between e body and b body k frames?
Re: e body and b body [Re: oldtimer5151] #1578766
02/14/14 12:08 AM
02/14/14 12:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The angle of the steering box mounting plate. It tilts the center line of the pinion closer or further from the inner fenderwell. That moves the column a little. Not sure how much. Other than that it bolts in.
Doug
Re: e body and b body [Re: dvw] #1578767
02/14/14 12:32 AM
02/14/14 12:32 AM
Aubrey, Texas
O
O
Aubrey, Texas
A friend of mine has a rack and pinion set up in his b body k frame. I would like to change them to get some weight off my front end.
Re: e body and b body [Re: oldtimer5151] #1578768
02/14/14 12:57 AM
02/14/14 12:57 AM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Is this so it can steer like a covered wagon? It should make you feel like a young buck again. Lol
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: e body and b body [Re: oldtimer5151] #1578769
02/14/14 02:19 AM
02/14/14 02:19 AM
I took a 1968 Hemi Roadrunner K member and put it in a 1970 Cahllenger years ago to run NHRA stock Bolted in and all the steering hooked up fine as far as front end alignment and driving was concerned NHRA made me put a sway bar back in it, so that got a little sticky for one year
Re: e body and b body [Re: Cab_Burge] #1578770
02/14/14 07:51 AM
02/14/14 07:51 AM
Mo.
racerx Offline
racerx  Offline
Mo.
after wrecking the chally bout 10 years ago, i got one from the scrap yard and it fit fine
