Re: Four barrel carb for 318
[Re: 340clone]
#1578716
02/13/14 11:33 PM
02/13/14 11:33 PM
RapidRobert
That ain't too much carb for it. I'm sure it is significantly less than 600 cfm (measure its' bores). What symptoms are you having? I have an Eddy 1406 600 cfm on a DD 318 & it runs flawless. All OE AVS's are emission carbs and are lean plus the air door adjustment. I'd suggest converting to Eddy performer 2 step rods/primary jets from a strip kit with sizes close to whatever is in the AVS right now maybe going several thou smaller on the "cruise" step for a start. You WILL notice the difference but holler back with what's going on
[Re: 340clone]
#1578719
02/14/14 03:01 AM
02/14/14 03:01 AM
340clone
The issue I'm having is that it seems to be running too rich. Even when I think it's properly tuned, It's still has a bit of a gassy smell to the exhaust, enough to make your clothes reek! LOL. Engine only has about 500 miles on it. A friend of mine said it was that the carb was too much for the engine. I didn't see how either, but I've adjusted the heck out of it with no real luck...
[Re: 340clone]
#1578720
02/14/14 03:09 AM
02/14/14 03:09 AM
Posts: 3,344 Central TX
roe
Central TX
Be careful, running excessively lean will give you the same smell of fumes. That's what happened to me, and leaning it out to fix th "Rich" running, fume smelling condition only made it worst.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: Baxter61]
#1578722
02/14/14 08:57 AM
02/14/14 08:57 AM
Posts: 20,182 Park Forest, IL
slantzilla
Park Forest, IL
I would be more concerned about the port mismatch/vacuum leaks.
Re: Four barrel carb for 318 *DELETED*
[Re: slantzilla]
#1578723
02/14/14 09:44 AM
02/14/14 09:44 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Port mismatch?
Right, keep believing that one
[Re: Supercuda]
#1578724
02/14/14 12:55 PM
02/14/14 12:55 PM
RapidRobert
I would check the float levels/float saturation/float linkage/needle condition as it might be a carb rich issue. What adjustments have you done? do the boosters drip at idle? As said a lean misfire can kick up the same symptoms as the unburned mixture just goes out the tailpipe where you smell it just like you would smell it if it was excessively rich from a carb issue. regarding a vac leak, how does it run/is there any hesitation anywhere?
