front disc brake conversion questions #15775
07/21/05 10:17 PM
07/21/05 10:17 PM
Anonymous OP
Anonymous OP
well, being a old die hard i never thought i'd ask this. has anybody had any experience converting to front discs on an early b-body without a power assist? i'm at my wits end on my 65 coronet. everything in the brake system is new. it has praise dyno ceramic-metallic shoes and 11" drums. i have a nice firm pedal but i almost need to use both feet to stop the thing! the pedal effort it takes to stop is ridiculous. my 69 r/t has virtually the same system, except for asbestos shoes, and stops reasonably well. i've been reluctant to convert because i've had disc brake cars that wouldn't stop. any ideas?
Re: front disc brake conversion questions #15776
07/21/05 10:43 PM
07/21/05 10:43 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I think those ceramic shoes have to be hot to start working right. You might try larger bore wheel cylinders or a smaller bore master to get more squeeze on the shoes. A brake booster would help.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: front disc brake conversion questions #15777
07/21/05 10:49 PM
07/21/05 10:49 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
The '73-6 a-body disc spindle fit the early b-bodies too. My brother used them on his '64 Dodge 440 and even used the a-body hoses.btw he used a junkyard aluminum dakota power brake master cyl but installed it as a manual master cylinder with no booster on his car. Stops good with no issues.
Re: front disc brake conversion questions #15778
07/22/05 12:04 AM
07/22/05 12:04 AM
Kansas
64Belvedere Offline
super street
64Belvedere  Offline
super street
Kansas
Maybe you could put some regular disc brake pads on and see if the braking action improves (after they "bed in"). Otherwise, I'd say it's the master cylinder bore diameter. Don't quote me on this, but I think a bigger bore makes for a harder pedal, and smaller bore makes for easier pedal effort. I used regular NAPA pads and a manual master cylinder from a '70 Belvedere application (no idea what the bore diameter is) and my '64 stops just fine.
[image][/image]
Re: front disc brake conversion questions #15779
07/22/05 01:16 AM
07/22/05 01:16 AM
AndyF Offline
AndyF  Offline
I've put a bunch of different manual brake setups on my '65 Coronet. They've all worked great with very good pedal feel. The easiest solution is to take the whole setup from a 1973 to 1976 A body car and just bolt it on there.
Re: front disc brake conversion questions #15780
07/22/05 01:22 AM
07/22/05 01:22 AM
Anonymous OP
Anonymous OP
I think you have a wrong size mastercylinder. I run 13,15" discs with big red calipers, with Hawk blue - will outbrake almost anything!
Re: front disc brake conversion questions #15781
07/22/05 02:26 AM
07/22/05 02:26 AM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
It sounds very similar to what happened to me. I had two new front drums and brake shoes put on my car ('67 Barracuda) back in December. The brakes would haul the car down from speed, but it just did not want to stop at all. I had to use two feet and it still would just barely stop. My front-end guy had put Raybestos bonded shoes on it. He didn't do anything other than change over to Bendix riveted shoes and everything works fine now. For some reason, the Raybestos shoes just didn't react well with the drums (btw, I got the drums from the Paddock, and I think they also were Raybestos).
Re: front disc brake conversion questions [Re: Fab64] #15782
07/22/05 06:03 AM
07/22/05 06:03 AM
Anonymous OP
Anonymous OP
Like Andy said,there are lotsa' option's out there,I used '81 cordoba units on my 63 sport Fury,and on several later 68/69 RR's,but I'd turf the oem style pre '66 single pot m/cyl. my '62-64 Fury's have alway's been fine with 11" drums,I just grabbed a set of 11" drums from a '68 charger,that is in my shop for paint,my buddy doesn't want them,I'd rather bolt them on my '62 fury than the disc's, I bought a supply of NOS m/cyl's for a 66-67 belvedere years ago, and switched up to that dual reservoir,manual drum style m/cyl.with no booster,I think you should try a different set of shoes first,and let us know which master cyl. you are using,maybe you have a line or distribution valve blockage,bad wheel cyl. ??, could be something minor,the 11" should work with a lot less effort,,If you think you need it,I do have a '70 B body booster and manual master cyl. for drum brakes,kickin' around here someplace.
Re: front disc brake conversion questions #15783
07/22/05 06:10 AM
07/22/05 06:10 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Find out if the drumshoes make contact over their entire surface-area. If not, they probably don't follow the same arc and diameter of the drum and need to be 'curved' to match the drums better.
A smaller MC could help aswell probably.
Re: front disc brake conversion questions #15784
07/22/05 06:17 AM
07/22/05 06:17 AM
Norman, OK
426Savoy Offline
426Savoy  Offline
Norman, OK
I converted my 64 Fury over using the 73-76 A body set-up and didn't use a power booster. The setup works great.
Re: front disc brake conversion questions #15785
07/22/05 12:04 PM
07/22/05 12:04 PM
AndyF Offline
AndyF  Offline
Dusta, sounds like you're happy with your setup. Maybe start a post sometimes showing your setup and the experience you're having road racing. We don't get many road racers on this board.
Re: front disc brake conversion questions [Re: AndyF] #15786
07/22/05 12:50 PM
07/22/05 12:50 PM
Anonymous OP
Anonymous OP
i've had 2 master cylinders on the car. the first was a 67-69 replacement dual with a 1" bore. i have the fine lines kit that splits the front from the back, new stainless lines, hoses, wheel cylinders, hardware, etc. a couple of weeks ago i put one of the alum master cylinders on (1 1/16" bore) i purchased from magnum hp (fits good). there wasn't any difference in pedal effort between the two. the ceremaic-metallic shoes don't fade with repeated 60mph stops but the pedal effort is too much. i've got a ton of $$$$ in this and hate to give up on it. i've thought about a power booster but would need the toggle linkage and plate to make it work. there aren't any old mopars in salvage yards around here to get parts.
i've thought about an ssbc or wilwood front conversion. don't know if it will work without a bunch of extra parts. i've heard that disc's without power assist have a lot of pedal effort also, don't know if thats true or not.
Re: front disc brake conversion questions [Re: AndyF] #15787
07/22/05 01:02 PM
07/22/05 01:02 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Everybody is telling you what to do and they don't have all the facts, I guess everybody here only reads what they want to and not whats posted by the topic starter! I can't give you a answer because of the following.
Gator- you say everything is new, but new with what? Nowhere do you state what componets you replaced them with. My question to you is " Are you running a single or dual Reseviour{sp?}? That can make all the difference in the world with whats going on with your brakes.
This post should be thrown out and starter over with you stateing ALLL the fact with your brake system and I'm sure the answers will be totally different.
Re: front disc brake conversion questions #15788
07/22/05 01:02 PM
07/22/05 01:02 PM
KY
rbds65 Offline
rbds65  Offline
KY
Gator, I don't see anything about a proportioning valve. You need one.
My '65 has '74 A-body setup, '67 replacement dual master cylinder, Finelines proportioning valve, and pedal feels same as with old single pot m.c.
Hope this helps you.
Re: front disc brake conversion questions #15789
07/22/05 02:42 PM
07/22/05 02:42 PM
AndyF Offline
AndyF  Offline
If you put the 11.75 B body rotors on there the pedal effort will be just fine with your aluminum master cylinder. You don't need any aftermarket stuff, just the late A body (or late B body) knuckles and the big 11.75 rotors.
I covered this entire swap on my website in the article section.
Re: front disc brake conversion questions [Re: AndyF] #15790
07/22/05 02:51 PM
07/22/05 02:51 PM
Andrewh Online content
Andrewh  Online Content
On a side note, I found a place that sells a power booster that works with the manual pedal. It has been shipped and I should have it by next week. Mine is a 65 coronet. I will post how it goes.
Re: front disc brake conversion questions [Re: stubbs300 ] #15791
07/22/05 02:53 PM
07/22/05 02:53 PM
Anonymous OP
Anonymous OP
both master cylinders that i have used are dual resevoir. the parts replaced are new wheel cylinders for 11" drums, new hoses, new brake lines, new springs, new Praise Dyno ceramic-metallic shoes and spring hardware. early b-bodies never had porportioning valves. the single resevoir master cylinder fed into a block that tee'ed out to the front and rear lines. i have never used that system. the Fine Lines conversion doesn't use any porportioning valve, it just simply splits the front and back. i thought my statement of parts in use was covered, maybe i wasn't clear, .
Re: front disc brake conversion questions #15792
07/22/05 05:34 PM
07/22/05 05:34 PM
Anonymous OP
Anonymous OP
I wonder if the shoe material simply requires more pedal effort, since you mentioned that your other car with standard type shoes seems to be fine. Another option would be to move the pushrod mount on the pedal to increase the leverage.
Re: front disc brake conversion questions #15793
07/22/05 09:03 PM
07/22/05 09:03 PM
Anonymous OP
Anonymous OP
greg, you may be right about the material. i have a set of new asbestos shoes (like whats on my 69 r/t) i probably ought to try before doing anything else.
Re: front disc brake conversion questions #15794
07/22/05 10:50 PM
07/22/05 10:50 PM
Chicago suburbs
dartgame Offline
dartgame  Offline
Chicago suburbs
Try the asbestos linings, Id bet the ceramic linings arent getting hot enough to work right.
