carb problem #1578624
02/13/14 05:40 PM
02/13/14 05:40 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
520 RB with a 1050 dom.i got my in gear idle at 14.5 on the afr guage.kruz is at 14.8.So i go to the track to do some t&t and they tell me i have to run a air filter(no hood).I have a K.N 2 in. by 14 w/a mesh top.when i put the air filter on, my AFR goes thru the roof.If i rev it up i can get it back down to 15.00 but then when i let up it goes to 17 then off the chart.i take the air filter off All is good.what the heck is goin on???
Re: carb problem [Re: bonefish] #1578625
02/13/14 06:00 PM
02/13/14 06:00 PM
Washington
skrews Offline
skrews  Offline
Washington
My 2 cents is that air cleaners redirect how the air enters the carb. Might be changing the signal on the air bleeds. Seems to be a consensus that those K&N filter lids cause a lot of weird turbulence too.
Re: carb problem [Re: skrews] #1578626
02/13/14 06:14 PM
02/13/14 06:14 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
OK i put a 4 in. element on it and its good to go.now for WOT!!
Re: carb problem [Re: skrews] #1578627
02/13/14 06:17 PM
02/13/14 06:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mr P-Body touched on this as well as others on what the carb "sees" and air from the sides AND on top seems like it would be goofy.......
Has anyone tried tapeing the side of the air filter closed and just getting the air from the lid alone? Kinda like a velocity stack..........
Re: carb problem [Re: Thumperdart] #1578628
02/13/14 06:32 PM
02/13/14 06:32 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i might try that,maby run a peice of ductape around the outside just to see.i hate this 4 in element stcking up.
Re: carb problem [Re: bonefish] #1578629
02/13/14 07:21 PM
02/13/14 07:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the air coming in the side(most of the flow is
there) and the top air crashing into the side air
you hurt the total air flow... I dont like drop air
bases either... too many direction changes for the
air to turn..... you can try taping off the outer
ring but I'm thinking the outer will have more air
flow... try taping off both one at a time... also
I would stack 2 elements for a smoother air flow
