Millage carb? #157848
11/27/08 08:37 PM
11/27/08 08:37 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
I've done everything I can with ignition and gearing to try and improve the millage in my 360 duster but I still only get about 13mpg. Here's the combo 360+0.030" "340" cam 2.02-1.625 "j"heads
4150-650dp holley 4sp w/2.76 gear 27" tall tires.
Everything I read about Holley carbs are that they are great for performance but poor for millage. I have done the small jets-6.5pv loosen up the acc pump thing but it really hasen't made much diffrence.
I would like to know what carb would be recomended to try and get some better millage out of this thing. I don't have room for a adaptor so it needs to be a square bore"flange" carb. Do the edelbrock's typically give better fuel economy?
Re: Millage carb? [Re: mod5v] #157849
11/27/08 09:24 PM
11/27/08 09:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
4150-650dp holley
There you go a double pumper. Picked ther worst possible carb for mileage, imo.
Had a very similar setup in an 87 Diplomat, 360 (same cam but 1.88/160 valves), 4 speed, 2.94SG rear, P255/60R15 tires. But I ran an Edelbrock 1406 carb, 600 cfm electric choke. On the highway it'd pull low 20's for mileage. This on a car probably heavier and less aerodynamic than your Duster.
So yeah Edelbrock's can get beter mileage than a double pumper.
Don't be the exception.
Re: Millage carb? [Re: Supercuda] #157850
11/27/08 09:55 PM
11/27/08 09:55 PM
1st choice(by far) 600 eddie 2nd choice 600 vac holley but go with either a reworked one, one of the aftermarket clones of it, a complete carb or maybe a Proform main body which gets good reviews maybe aftermarket metering blocks.
Re: Millage carb? [Re: mod5v] #157851
11/27/08 10:45 PM
11/27/08 10:45 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Thermoquad best of both worlds for the street.
Re: Millage carb? [Re: mod5v] #157852
11/27/08 10:51 PM
11/27/08 10:51 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Very simple ... Performer or SP2P intake with a ThermoQuad carb. NO square-bore flange carb is even in the ball-park.
Re: Millage carb? [Re: dOoC] #157853
11/28/08 12:36 AM
11/28/08 12:36 AM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
Well the thing is I put this togather with parts I had stashed away over the years. I'd rather not put to much into this as I am trying to save up for a magnum based 360 or 408. I hope to do that in aa couple of years so I wanted to just try a carb prefeably used that had a history of reasonnably good millage.
Re: Millage carb? [Re: mod5v] #157854
11/28/08 01:18 AM
11/28/08 01:18 AM
I'd find a used 600 eddie put a kit in it & I think you'd be happy with that & not out too much money.
Re: Millage carb? [Re: RapidRobert] #157855
11/28/08 02:47 AM
11/28/08 02:47 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I disagree that a square bore carb can't do as well as a spread.
I've tuned a 625 road demon on my 440 winni. The 440 is original, well worn, and burns some oil.
I get 8 mpg (us gallon) and 10mpg Cdn gallon towing my car over some of the highest mountain passes in the world.
Car's 3800pounds, plus the 18 ft trailer, the tools, and of course the winni with the gear and the family in it, which I'm scared to even guess at the weight on. It get's better milleage than any gas tow rig I've ever owned. TQ or otherwise.
But back to the build....
I agree that the dp is going to hurt mileage, BUT it should only be a factor when your romping on it. In the primary's it shouldn't matter.
I notice no cam specs. A 340 was a performance motor, so it wants to perform. Not economize.
IMHO I think the 13 mpusg you are getting isn't too far off of anything you can hope for.
If there is something wrong with the holley then you may see some improvement.
A smaller carb (not smaller jets) may improve velocity, and fuel atomization, so if you can find something smaller (regardless of brand) you may see an improvement there also.
Put a vacuum gauge on it, and watch it while you drive. Your driving habits may adjust a bit and help you too.
It's very difficult to build an old motor to perform, and then get mileage out of it.
Re: Millage carb? [Re: mod5v] #157856
11/28/08 08:48 AM
11/28/08 08:48 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Grab an Eddy, They are very tunable on the slow speed circuits. Sometimes advancing your cam timing will net you a couple miles per gallon also.
Re: Millage carb? [Re: dave571] #157857
11/28/08 08:56 AM
11/28/08 08:56 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
The reason Double Pumpers are not MPG friendly isn't the additional accel pump, because if you are driving for mileage, it should never operate.
Double pumpers have smaller power valve channel restrictors so if you tune for power, cruise will be rich. If you tune for economy, power will be lean.
Opening up the PVCR's will change it but I wouldn't go fooling with it without a good way to check air fuel ratio.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Millage carb? [Re: CJK440] #157858
11/28/08 11:34 AM
11/28/08 11:34 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
back in the day i found that the factory avs would mileage better than a holley counterpart. the 3 step metering rods may have been a big factor. the edelbrock 650 avs is nearly identical in size to a 340 avs.
Re: Millage carb? [Re: mod5v] #157859
11/28/08 11:42 AM
11/28/08 11:42 AM
For mileage I like the TQ best followed by the Carter AVS.
Sheldon
Re: Millage carb? [Re: mod5v] #157860
11/28/08 01:32 PM
11/28/08 01:32 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
It is not a carb
but if what you desire is better fuel economy
and also the ability to get best power
a TBI or MPSFI setup
could do up to 30% better.
If you are on a limited budget
factory EFI units pulled
from a junkyard
(Chrysler, GM or Ford units all could work)
would give acceptable results
I would also urge not neglecting
the easy Highway MPG gains
that can come from aerodynamics
or easier rolling resistance tires
It is hard to improve engine efficiency
but this article does show
that improvements have been made
with operating near the limit of lean air/fuel
including much research by Chrysler:
http://www.designnews.com/article/9710-Thirty_Year_Quest_for_Lean_Burn.php
it is doable
to get your Duster over 20 MPG
without breaking the bank
Re: Millage carb? #157861
11/28/08 01:47 PM
11/28/08 01:47 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
The reason for no cam specs is I don't know what it is for sure. I pulled it from a 318 I had and mesured the lobe lift and the best I could do is somewere in the .45" range with 1.5 rockers so I'm guessing a 340 size cam. I know my build is just wack but its what I had.
Above cam
.03 over 360
Sp 405 pistons (mybe 8.8-1)
587 heads stage II hughes port w/11/32 valves.
wieand dualplane intake#7507
blackjack headers--2 1/2" exh
8 3/4 w 2.76 gear Have 3.23 and 3.91
standard 4 sp working on a O/D 4sp
I drive to work regularly and its about 26 miles each way highway but sometimes heavy traffic. usually cruise between 60-70mph 2100-2500rpm.
It just seems that no matter what I do my millage stays withing 1mpg.So I'm thinking that the "cruise" fuel mixture on these holleys is just really rich?
Re: Millage carb? [Re: mod5v] #157862
11/28/08 03:28 PM
11/28/08 03:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the double pumpers are biased toward larger main jets. some of them, or maybe all (?) have smaller power valve resriction orifices than some of the vacuum carbs. this means you need larger jets for wide open throttle, which effects cruise. if you have a square bore manifold try a carter or edelbrock with the small 1 3/16" primarys.
Re: Millage carb? [Re: mod5v] #157863
11/28/08 04:04 PM
11/28/08 04:04 PM
Virginia
JimG Offline
JimG  Offline
Virginia
Hi Mod5v:
As CKJ440 hinted - have you considered purchasing a wideband O2 meter and watching what's going on with your AFR as you drive? It can be a real eye opener.
Every performance oriented Holley I've ever seen was rich at light cruise. It can be tuned out, but it's very hard to do when you can't measure what's happening.
In the summer months, I run an older 950 HP series, and when it gets cold, I switch to an ancient 3310-1 (b/c it has a choke). After some work, both cruise in the 14 - 15:0 AFR neighborhood.
I can tell you what typically has to be done if you're interested. I know you were asking about other carbs, I just thought I'd throw another option your way.
Re: Millage carb? [Re: mod5v] #157864
11/28/08 05:20 PM
11/28/08 05:20 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Put on a 600 Holley vac secondary.It will work fine.I ran a 318 with 340 cam and same gearing as your car and got 22mpg.Mine was jetted at 64pri,left the stock metering plate in the back.
Nautilus Racing-
Re: Millage carb? [Re: Chris2581] #157865
11/28/08 07:53 PM
11/28/08 07:53 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Get a LM-1 meter. Properly setup and tuned a thermoquad would be real tough to beat. Easier to find and tune would be the Edelbrock.
I had a set of 750 eddies that I modified and tuned with my LM-1 on my tunnelrammed 528 hemi. It got an honest 10mpg driving it nice. The same motor and intake with a set of tuned 850 thermoquads netted me 13.18mpg, (driving it real nice). Dave
Re: Millage carb? [Re: quickd100] #157866
11/28/08 09:17 PM
11/28/08 09:17 PM
Fortworth TX
mod5v Offline OP
mod5v  Offline OP
Fortworth TX
As some of you may have deduced I am on a strict budget and I don't think a wideband 02 is in it. I also recently moved from Michigan to fortworth TX and was not able to bring any of my gerage goodies with me. I don't have the room to put the tools nor do I have anywhere to park a beater car while I work on the duster so any work I do has to be done on weekends and the car has to be ready to get me to work on Monday.I can pick up a used eddy from e-bay or a swapmeet for 100.00 or so and just wondered if it would be worth it. If all it gets me is a mile or 2 per gallon it's probably not worth it as it would take a couple of years to pay back and I hope to have a place to keep the car by then so I don't have to drive it every day. When that happens I hope to build a more performance oriented engine and have some fun with the car.
Re: Millage carb? [Re: mod5v] #157867
11/28/08 10:07 PM
11/28/08 10:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you get an Ebay carb, any carb, you had best budget for a rebuild kit too. This is yet another area the AFB style cab wins out over the Holley, extremely esy to rebuild and Edelbrock has the owner's manual online, so you can verify settings, jets and rods.
If you were closer to me, I live in San Angelo, I could help, but I am sure there is a Mopaters member around you.
