Tranny tail housing counterweight question #1578171
02/12/14 10:37 PM
02/12/14 10:37 PM
Western PA
O
OldMoparMan Offline OP
O
Western PA
I swapped out the 904 tranny with a counterweight on the tail for a 518 that didn't have one. Should I put the weight on the 518 since it has the holes to mount it or will I just be adding weight to the car.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: Tranny tail housing counterweight question [Re: OldMoparMan] #1578172
02/12/14 11:50 PM
02/12/14 11:50 PM
scratchnfotraction Offline
it is tailshaft damper, wont hurt either way.
I have a damper myself but lost the bolts. could you post a pic of your damper and bolts?
maybe I can ID what they look like and spot them in my bolt bin.
Re: Tranny tail housing counterweight question [Re: OldMoparMan] #1578173
02/13/14 04:21 PM
02/13/14 04:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Once you change the configuration that required the weight, the weight isn't needed.
Re: Tranny tail housing counterweight question [Re: OldMoparMan] #1578174
02/13/14 11:00 PM
02/13/14 11:00 PM
Western PA
O
O
Western PA
Thanks John
Mike the bolts are 5/16 X 1 1/4" and the washers are 1 1/8" X .065 thick
Re: Tranny tail housing counterweight question [Re: OldMoparMan] #1578175
02/14/14 11:25 AM
02/14/14 11:25 AM
thanks, i forgot it had washers. that should help scratch them up.
