Recommend a brand and source for U-joints #1578002
02/12/14 01:14 PM
02/12/14 01:14 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I have always used Spicer solid joints in my cars. But they are apparently not available anymore. I want to change the parts store hollow joints in the 4 speed Barracuda to some quality forged units just for safety's sake.
So steer me towards the joints you have had good success with.
Thanks guys!
Master, again and still
Re: Recommend a brand and source for U-joints [Re: DaveRS23] #1578003
02/12/14 01:20 PM
02/12/14 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this a street car... how much power.. what U-joint
are you running now.... I have found that most any
good joint WITHOUT the grease fitting will take a lot
of torque
Re: Recommend a brand and source for U-joints [Re: MR_P_BODY] #1578004
02/12/14 01:33 PM
02/12/14 01:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run Brute Force from Advance.They carry a lifetime warranty and are solid.Rocky
Chrysler Firepower
Re: Recommend a brand and source for U-joints [Re: MR_P_BODY] #1578005
02/12/14 01:39 PM
02/12/14 01:39 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Mild 360, 4 speed, 3.91s, street tires, 527 rear joint.
My local parts store don't even list a joint with out the grease fitting.
The car may not even need a heavier joint, but I have no faith in the cheap joints and feel that quality joints would be cheap insurance.
Re: Recommend a brand and source for U-joints [Re: DaveRS23] #1578006
02/12/14 02:02 PM
02/12/14 02:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mainly I use Spicer but I have used the Brute Force
once... there is one other I've used but I cant remember
the name right now... did Spicer just change the number
on the 527 or is it discontinued ... the 7260 to 7290
is a pretty common joint for use mopar bumms
Re: Recommend a brand and source for U-joints [Re: MR_P_BODY] #1578007
02/12/14 02:14 PM
02/12/14 02:14 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
The only info I can find for the Spicer 5-527x is that is has been discontinued. And I have not been able to find a superseded number.
I called Advance and gave them all the brands and numbers I had for the 527 and they could not cross them to any Brute Force number.
Re: Recommend a brand and source for U-joints [Re: DaveRS23] #1578008
02/12/14 02:22 PM
02/12/14 02:22 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thanks guys!
I have bought most of my U joints from Car Quest and they have always been Spicer's I have used the Brute Force thru Advance with good luck and I also know the local 4X4 guys swear by them, and these guys tear up alot of stuff. some of the manufactures will put the zerk fitting in the cap and these usually have a heavier body (cross) and also have a much smaller grease hole thru them, one of the things that some of the old time racers have told me that if you install the joint where as the torque is toward the zerk fitting as opposed to away from it that a standard joint will take more abuse befor it fails, if that makes sense.
Re: Recommend a brand and source for U-joints [Re: DaveRS23] #1578009
02/12/14 02:57 PM
02/12/14 02:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been runnin the same big spicer joints 13+ years now w/no issues and they still roll smoothly............no zerk fitting..........
Re: Recommend a brand and source for U-joints [Re: Thumperdart] #1578010
02/12/14 03:07 PM
02/12/14 03:07 PM
Locomotion Offline
Locomotion  Offline
They better not have discontinued the 7260 solid Spicer joints! I've had the same ones in my car for years with no issues. Got conversion 7260/1330 joints for a spare driveshaft as well. (Aftermarket driveshaft end yokes.)
Re: Recommend a brand and source for U-joints [Re: Locomotion] #1578011
02/12/14 03:15 PM
02/12/14 03:15 PM
dogdays Offline
dogdays  Offline
Many times Rockauto will have leftovers and may be a source of a discontinued joint.
R.
Re: Recommend a brand and source for U-joints [Re: dogdays] #1578012
02/12/14 03:31 PM
02/12/14 03:31 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
I use and Pyle Bros. Differentials out of Houston uses Precision Joints that can be bought from Napa or O'Reily's.
Back in the swing of things at Painless again! Great to be back!
Re: Recommend a brand and source for U-joints [Re: BJS racing] #1578013
02/12/14 06:23 PM
02/12/14 06:23 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use Neapco HD joint with the red seals,they are chromemoly solid spider joints. They are the company that makes the Lakewood brute strength joints.
Gus
64 Plymouth Savoy
Dana 60
Re: Recommend a brand and source for U-joints [Re: fourgearsavoy] #1578014
02/12/14 06:40 PM
02/12/14 06:40 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Recommend a brand and source for U-joints [Re: DaveRS23] #1578015
02/12/14 08:54 PM
02/12/14 08:54 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Dave I agree Spicer is as good as it gets. You may be able to get them from Driveshafts Unlimited in Arnold, Mo. That's what they use on all their work. Excellent source for steel driveshafts. 3608 Market Place, Arnold, Mo.63010 1-636-296-2841 or 1-800-300-2841. Let us know if you find anything closer. Might want to try Mancini too.
Re: Recommend a brand and source for U-joints [Re: 5spdcuda] #1578016
02/12/14 10:01 PM
02/12/14 10:01 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Well, so far no parts store here in town have a heavy duty line of joints that have the adapter joint in their line. I have tried Precision and Brute Force, neither make the 527 style joint.
Mancini has a couple of 527 joints, but I don't know anything about them. And they are $50-$60 plus shipping!
I may have to pay that kind of money, but geez, the forged Spicers were less than $20.
What brand does Dr Diff recommend?
Re: Recommend a brand and source for U-joints [Re: DaveRS23] #1578017
02/12/14 10:46 PM
02/12/14 10:46 PM
PA.
"Little"John
"Little"John
PA.
Is this the one you are looking for.
http://www.ebay.com/itm/Spicer-U-Joint-K...245&vxp=mtr
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Recommend a brand and source for U-joints [Re: pittsburghracer] #1578018
02/12/14 10:52 PM
02/12/14 10:52 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Recommend a brand and source for U-joints [Re: pittsburghracer] #1578019
02/12/14 11:09 PM
02/12/14 11:09 PM
dogdays Offline
dogdays  Offline
Precision 347
MOOG 347
NEAPCO 2-0527
R.
Re: Recommend a brand and source for U-joints [Re: pittsburghracer] #1578020
02/12/14 11:29 PM
02/12/14 11:29 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
That joint has been on there for a long time. And that is because it is a hollow cast joint. I think it is a re-box. If it is a Spicer, I have never seen one quite like it. Anyway, I can get hollow, cast joints locally for a lot less money. In fact, that is what is in the car now.
Re: Recommend a brand and source for U-joints [Re: dogdays] #1578021
02/12/14 11:32 PM
02/12/14 11:32 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Precision 347
MOOG 347
NEAPCO 2-0527
R.
The parts stores tell me that those are all hollow, cast joints. I already have that. I was wanting a solid and hopefully forged joint.
