Re: 440 Block that won't work with 130 Tooth Flywheel?
[Re: Steve Bryant]
#1577998
02/12/14 12:54 PM
02/12/14 12:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The bell determines the flywheel needed, not the block.
The starter bolts to the bell, if they use the right bell with the flywheel you have it will work, that or they need to get the right flywheel to match their dyno scatter shield.
[Re: Supercuda]
#1577999
02/12/14 01:17 PM
02/12/14 01:17 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I agree the bell determines the flywheel.Most scatter shields use either a 130 or 143 flywheel.Lakewood makes a kit to use the 130.Either they need a 130 tooth bell or a 143 flywheel.If your car has a 130 bell it will work with the 130 wheel.If they cant figure that out Id be scared of what they did for machine work.Rocky
Chrysler Firepower
[Re: Supercuda]
#1578000
02/12/14 01:21 PM
02/12/14 01:21 PM
RapidRobert
X2 what SC said, I ran into that too as alot of shops just dont dyno many Mopars/no familiarity
