Page 8 of 22 1 2 6 7 8 9 10 21 22
Re: Let the Hemi swap begin [Re: RylisPro] #1577479
11/03/14 04:30 AM
11/03/14 04:30 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Cool!
So 2008 5.7 stuff will work on a 6.4?
Good to know!
I'm a newb when it comes to Gen III stuff haha!
No, you've got to be careful about the break downs.
Here it is in a nutshell:
Early style
03-08 Truck 5.7
05-08 Car 5.7
06-09 Car 6.1
Late (Eagle and apache)
09+ Car 5.7
09+ Truck 5.7
10+ Car 6.4
10+ Truck 6.4
You can't swap the timing covers between early and late (not that I know..)
You need to center your build around the timing cover. If you want a 6.4 then you need to source all the accessories for that. The biggest degree of interchangeability is in the cylinder heads and intakes.
If I was going to put a stock motor in one, it would be a factory stock 6.4 with just a cam and lockout kit plus a 6.1 intake manifold.
If you're talking about an early 5.7/6.1 392 stroker, that's a different animal. You buy parts based on the block/timing cover.
I started with the 6.1 due to circumstance and luck, I had to build the whole thing up by each nut and bolt. I don't advise that for anyone, it's really not cost effective. I would have been farther ahead just buying a broken 5.7 early motor from a car and pulling all the odds and ends off of that.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577480
11/03/14 05:32 AM
11/03/14 05:32 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Oh wow I had no idea. It turns out the engine I want will be based off of a 6.1
Thanks for the heads up!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: AlexP] #1577481
11/03/14 05:39 AM
11/03/14 05:39 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
The fact that gets me everytime is when someone says they want to save money by going carb on a motor like this.
Even if you have nice carb, the MSD ignition controller is still $800 and then you may or may not have to do anything with your fuel system.
That wasnt my reason...mine was appearance and that I couldnt face the EFI learning curve..
But you should be fair with your costings Alex.... I didnt have to swap out my fuel pump, fuel line, use a fuel accumulator or put on a return line...
But yes....its never going to be able to run the camshaft LSA you EFI guys can....which dictates how much duration I can get away with.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Let the Hemi swap begin [Re: AlexP] #1577482
11/03/14 06:09 AM
11/03/14 06:09 AM
Moparmal Offline
Moparmal  Offline
Also, I hate my taxi cab dash. It's never worked and when I went with Painless wiring in the car I never even bothered hooking it up. I was about to wire a bunch of auxillary gauges to keep tabs on things, but I'm not doing that any longer.
I'm going to use Shadow Dash MS for my temp, pressure, voltage, rpm, warning lights and Speedo. All of which will show off of my MS3 box. I might be able to get my fuel sending unit to be read by the MS3 box. I'm just going to make a nice magnetic mount for the Android Device of my choice (Nexus 7 most likely) and use that for the near future. If I leave the car unattended, I'll hide it or put it in my pocket.
This is a Galaxy S3 in a 68 Chevelle.
Youtube Video
D,amn that is somewhat cool!
But if I bought a Nexus 7... Id have to "retire" it...
Re: Let the Hemi swap begin [Re: AlexP] #1577483
11/03/14 06:48 AM
11/03/14 06:48 AM
Moparmal Offline
Moparmal  Offline
Milodon Pan in place.
I tried the tin Milodon pan with the factory gasket..ended up with leaks - ended up combining the factory gasket with the milodon cork gasket and it sealed like Fort Knox....
This was after I had to drop the cross member to remove the pan...
Check your pinion angle with those TTI mounts as well......
Just a heads up.
Re: Let the Hemi swap begin [Re: AlexP] #1577484
11/03/14 10:57 AM
11/03/14 10:57 AM
USA
Consulier Offline
Consulier  Offline
USA
I'll give the benefit of the doubt because these headers are from 2007 and weren't used until now. I don't know what changes have been made to the jig. I will say that TTI does have amazing customer service and I wouldn't use any other header for this swap. I have no doubt that Dougs is lightyears behind TTI. I talked to them on the phone and I wasn't impressed.
My 2" are from 2012 and they hit everything. Called TTI, no changes, "they should clear the starter by 1/2"... not even close. Wouldn't clear the T Bars, hit a bunch of other stuff... junk.
Honestly, their customer service is nice on the phone, but offers to correct nothing. I'm pretty much fed up with them. The headers don't even come close to fitting, the motor mounts didn't even come close to fitting, why even sell the stuff? On top of that, why does everyone keep defending them?
As far as I'm concerned, for Gen 3 Hemi swaps, TTI and Milodon can fall off the face of the earth and we would be just fine.
Re: Let the Hemi swap begin [Re: Moparmal] #1577485
11/03/14 11:57 AM
11/03/14 11:57 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I ran the carter pump, 1/2" stainless hardline feed and return line and regulator with my carb from the B motor.
I only needed the accumulator, GSL392 and my fittings.
Re: Let the Hemi swap begin [Re: Moparmal] #1577486
11/03/14 11:59 AM
11/03/14 11:59 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Just a heads up.
I've sealed 3 pans the same way. Two of those times we even reused the same gasket. It never leaked. The idea of using those cork gaskets made me cringe. I used a few dabs of the Mopar brand RTV in the same spots on my pan, and I really don't expect to have any issues.
Re: Let the Hemi swap begin [Re: Consulier] #1577487
11/03/14 12:37 PM
11/03/14 12:37 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I am not defending TTI, I have never bought any of their stuff but I know they recently came out with a revised set of headers for A bodies with Borgeson boxes part# 61WP.
As far as headers not fitting, maybe it is a combination of header primary size, torsion bar size, body style and how more or less crappy your chassis was welded up 40 years ago? Other than TTI headers or Milodon for the pan what other options is there besides custom $,$$$.$$?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: RylisPro] #1577488
11/03/14 01:29 PM
11/03/14 01:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Their mounts suck, and that in turn makes the headers fit like dog doo. Milodon gouged us Mopar guys pretty bad, and by the way my pickup tube is back ordered until the 17th. That should give them enough time to make one that fits.
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: RylisPro] #1577489
11/03/14 01:48 PM
11/03/14 01:48 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I have the 61WP headers in my car, and recommend them to those that want power steering with an a body. The fit is so tight you're going to need fitting (aka- Hammer).
You can run the 5.7 truck gasket with the milodon pan. The first time I installed it there was a leak - the gasket ribbing doesn't line up with the pan in the front corners. The second and third time a little mopar brand rtv solved the issue.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: RylisPro] #1577490
11/03/14 04:39 PM
11/03/14 04:39 PM
USA
Consulier Offline
Consulier  Offline
USA
That is great if you run a 6.1. Called them, can you make a set for 6.4... nope, no plans to do that.
Can you weld on a 6.4 flange to a set of 1 3/4" 5.7 headers so I can possibly pick up some area where your 2" hit everything... nope.
If a stock K member still bolts on without any problems, I don't think Chrysler build quality is an issue. When you put on exactly what they tell you for a starter and the tube still doesn't even come close to clearing, their build quality is the problem.
At this point for me, custom would have been cheaper. The amount of time I have into the trial and error fitting with Milodon and TTI is beyond ridiculous. Ended up with custom mounts, custom dented/massaged headers and a custom oil pickup. Gee, thanks so much for the well engineered and designed parts... not.
Re: Let the Hemi swap begin [Re: Consulier] #1577491
11/03/14 05:07 PM
11/03/14 05:07 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
It sounds like it's all behind you now, but 6.1 headers work fine on a 6.4.
Edit to add: flanges and ports mount up fine. Don't know block and mounts, though.
Re: Let the Hemi swap begin [Re: AlexP] #1577492
11/03/14 10:05 PM
11/03/14 10:05 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I don't know by part number, but I know by application.
The alternator is a re-manned 05-08 5.7 car unit and my ps pump is an 03-08 5.7 car.
I'll use an external reservoir on the PS pump. Just factory stuff mounted to the fender. The easy thing to do would be to get a Jeep SRT8 Powersteering pump, with the built in reservoir...but I've not come across one for thr right price yet.
Alex,
Did you check the pressure output of the PS pump against the steering gear you are using?
New and old are not always compatible.
- Stu Harmon
Re: Let the Hemi swap begin [Re: feets] #1577493
11/03/14 11:23 PM
11/03/14 11:23 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
No. Now that you mention it, I did hear about people saying that early on.
I'm using a firm feel stage 4 box. I probably should call them up.
Re: Let the Hemi swap begin [Re: AlexP] #1577494
11/04/14 01:23 AM
11/04/14 01:23 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You're going to have a problem. You need to back off the pressure at the pump. Modern systems can run well over 1600 psi but some of the old gear boxes are only set up for half of that.
- Stu Harmon
Re: Let the Hemi swap begin [Re: feets] #1577495
11/04/14 10:34 AM
11/04/14 10:34 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I did not have a problem in the ~1500 miles I ran the factory box with the Hemi pump. Quite a few guys do it.
The 'on paper' concern has been discussed. However I do not recall hearing of anyone who had an issue with it. Maybe someone will chime in?
Emil runs a lower pressure pump from a different application. Should be a good alternative.
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577496
11/04/14 11:55 AM
11/04/14 11:55 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Can you access the regulator in the new pumps and shim it down like the older units?
- Stu Harmon
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577497
11/04/14 12:07 PM
11/04/14 12:07 PM
USA
Consulier Offline
Consulier  Offline
USA
Keisler's Cuda had a 6.1 pump with a Firm Feel box. It spit out at least 2 pumps and at least 1 box started leaking. He probably put 10k+ miles on it, so it sounds like it might take some time to see the problems
Re: Let the Hemi swap begin [Re: Consulier] #1577498
11/04/14 12:28 PM
11/04/14 12:28 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I've killed a pump. Added a cooler and larger pulley, haven't killed another.
I did have the input shaft seal leak on the original box. Replaced it and I was GTG. Yes- limited to 1500 miles.
