Purpose of trunk vent flaps on early Barracudas???? #157742
11/27/08 03:17 PM
11/27/08 03:17 PM
NJ
N
Nvr4Get911 Offline OP
N
NJ
Anyone know why MaMopar put the trunk vent flaps on the early ('64-'66) Barracudas located under the rear window chrome trim as you lift the trunk lid up???? What are their function? Should I clog them to prevent any fumes from exhaust pipes leaking in?
Happy Thanksgiving...273HYPO
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: Nvr4Get911] #157743
11/27/08 03:23 PM
11/27/08 03:23 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think it's for flow through ventilation. They carried over this idea for the 67 and 68 Barracudas with flaps on the bottom of the doors. I don't know if they did that in 69?
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: autoxcuda] #157744
11/28/08 09:11 AM
11/28/08 09:11 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
correct- 66-67 Chargers had the same thing!
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: 71_deputy] #157745
11/28/08 09:24 AM
11/28/08 09:24 AM
NJ
N
N
NJ
Is that why there a four holes under the rear window chrome trim because they act as inside cabin ventilation which flows thru the trunk vent flaps?
Thx, 273HYPO
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: Nvr4Get911] #157746
11/28/08 01:35 PM
11/28/08 01:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thx, 273HYPO
I think it would help prevent and reduce rear window fogging with the air passing over it.
All of those pre 74 rear window defoggers do is force air sucked from the inside speaker grille back onto the rear window.
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: autoxcuda] #157747
11/28/08 01:37 PM
11/28/08 01:37 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
the holes i think you are referring to are to get to the trim screws
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: DJVCuda] #157748
11/28/08 02:18 PM
11/28/08 02:18 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
The Vents w/ flaps you mentioned serve several purposes based on brochures and other info. I have read though the years.
The first purpose was allow you to close the doors easier. When you close the door of the car with all windows in the up position, the flaps allowed air to escape reducing air pressure in the car and allowed the doors to shut easier. The reality is that the cars aren't that tight to begin with so the effort needed to close the door is probably not changed too much.
The second purpose was for flow through air when the vents were open.
The slit in the side rear trim panel on the inside of the car near the back glass was to help with defogging the rear window.
You asked if you should plug them up. I would not recommend it. If water gets in there it will have no way of getting out and will begin to rust the body seams in that area. The flow through effect helps dry any moisture that might get in that area.
Joe
65 Barracuda
70 Challenger
Re: Purpose of trunk vent flaps on early Barracudas???? [Re: jrwoodjoe] #157749
11/28/08 05:32 PM
11/28/08 05:32 PM
NJ
N
N
NJ
Makes sense that the holes assist in air flow and accessing the trim. But I had another fella Barracuda owner tell me that they absolutely have their own plugs for these holes.
! [Re: Nvr4Get911] #157750
11/28/08 10:07 PM
11/28/08 10:07 PM
N
noisydart Offline
super gas
noisydart  Offline
super gas
N
This is a conundrum!
Re: ! [Re: noisydart] #157751
11/29/08 01:03 AM
11/29/08 01:03 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
plug em and then slam the door... you will suddenly realize why they are there when the back window blows into 9 million billion little shards.. dan
Re: ! [Re: ph23vo] #157752
11/29/08 01:22 AM
11/29/08 01:22 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
LARGE rear window glass + sudden increase in pressure = broken glass (in theory)
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
