Re: Let the Hemi swap begin
[Re: AlexP]
#1577362
02/20/14 04:01 AM
02/20/14 04:01 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Looks good! Where can you mount it? Can you put a pop can or a $1 bill next to the box for size comparison?
Mopar to the bone!!!
[Re: TC@HP2]
#1577367
02/21/14 11:36 PM
02/21/14 11:36 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I can't speak for his choice of parts, but I like bolt in parts for my car. The ease of install for this motor and the relative ease of the EFI will be great. By far, the most complex part of the car (I use that term loosely...its not really complex) is the fuel system. Carter P4601HP for my lift pump. I ran it as a single fuel pump before and it doesn't have a problem pulling fuel from the bottom of the tank. Feeling into the BCBroncos Fuel Accumulator. This will give me a 1qt reservoir of fuel at all times. This was a big part in making this car effective without a full race fuel tank or a heavily modified stock style tank. Its just a very affordable surge tank, props to wade (uhcoog1) for giving me this idea... A simple GSL392 Rotary vane inline external fuel pump. Good for 600hp all day long. A corvette fuel filter/fuel filter regulator. About $27 by wix, and keeps my engine bay clean by leaving all the extra plumbing back there. This will go up front through my 1/2" stock style fuel lines in stainless. I'm going to be blocking off my return line for now, it's not needed at the moment. I'll be feeding into a set of stock 6.1 fuel rails. Nothing fancy. Good for 600+ hp. KB retains these for their 2.8L blower kits. And finally a set of SRT4 stage 1 fuel injectors. Here is a breakdown of what hemi injectors will do... Stock 5.7- Bolt ons on a 5.7 Stock 6.1- Maxed out on a head and cam car Stock 6.4- +1 for a head and cam 6.1, not a huge improvement. SRT4 stage 1- Entry level max effort 6.1 and basic 426. Also suitable for stock displacement with a small forced induction build (vortech includes these with entry blower kits) SRT4 stage 2- Built 426 with small nitrous or boost. Above that, you can get any of the above rebuilt from any number of vendors up until about 1000hp. After that, something like Injector Dynamics ID1000 or ID2000 is needed to have excellent drive ability with that much power. I forsee my car getting a second GSL392, a forged 6.1 and some sort of forced induction. I've got a Vortech Kit for it, but I really want a Magnuson/Kenne Bell kit..just for the sound really. I'd be happy to lose 100hp over a centrifugal blower for that whine.
[Re: AlexP]
#1577368
02/22/14 12:49 AM
02/22/14 12:49 AM
Posts: 240 Shingle Springs Ca
haddixj
Shingle Springs Ca
Are you planning on going speed density or running a mass air flow sensor? Does the MS3x from them have the map daddy 4 bar sensor? I have MS3X for my chevelle LS swap and the dual map sensor is nice as it can be used to correct for altitude changes by comparing the static one and the engine map sensor. I have heard that the new MS3 Pro uses an external MAP
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
[Re: haddixj]
#1577369
02/22/14 12:54 AM
02/22/14 12:54 AM
AlexP
Houston, Tx
The 3g Hemi is built around Speed Density. I'll be using a factory sensor in the back of my 6.1 intake. The ECU will make judgements based on the MAP sensor and the intake air temperature sensor. Here is a breakdown of the features on this box. Quote:
MegaSquirt MS3
Gen3 Hemi Gold Box Standard features
· Controllers are factory configured for your Gen3 Hemi engine
· Start up program factory installed
· USB, RS232 and CAN communication
· Onboard SD card for Data logging
· 8 High Impedance injector drivers
· 8 High current ignition outputs. No additional boxes or coil drivers needed.
· Fuel pump output
· Fan output
· Stepper and PWM Idle Air Control outputs
· 2 Nitrous outputs
· Variable Valve timing output
· 12 volt tach output
· Two Step Input
· 2 Oxygen sensor inputs
· 2 Knock sensor inputs
· Nitrous input
· Data Log switch
· Dual table switch
· 3 additional general purpose inputs (on/off or frequency)
· 1 additional analog input
[Re: AlexP]
#1577370
02/22/14 01:32 AM
02/22/14 01:32 AM
72Swinger
Nebraska
Any pics to depict the size of that thing?
[Re: AlexP]
#1577371
02/22/14 02:02 AM
02/22/14 02:02 AM
haddixj
Shingle Springs Ca
Ok thanks I know some use a GM MAF sensor. The newer card type one is able to read a huge amount of flow and has been succesful with boosted apps.
[Re: 72Swinger]
#1577373
02/22/14 02:54 AM
02/22/14 02:54 AM
AlexP
Houston, Tx
7 in x 7 in and the mounting tabs are sliding to allow staggered placement.
[Re: Dan@Hotchkis]
#1577374
02/22/14 03:00 AM
02/22/14 03:00 AM
AlexP
Houston, Tx
Good to see another option for our cars. I was just reading up on a kit Mopar Action did an article on a year or so ago. Required the crank to be pulled to install a tone ring. Yikes. However, it allowed the use of GM ECU and all the OBDII diagnostics too...
Now that I see this, I don't know what route I would take.
The only perk I could see that the Delphi based systems have above this is the tuning aspect. There are so many more tuners out there. That being said, if I didn't want to ever tune it myself....I'd be running a hotwire kit with a factory Mopar ECU, get a Diablo Programmer and have someone knock out a tune via email in 3 shots.
Between the autotune function on this (as well as XFI) along with the megasquirt community online, my choice was easy.
I'm not one of those people to care about having ford or chevy parts on a mopar, but I can't see why someone would spend $2000 to have LS1 stuff on their car when there are better and cheaper options out there...unless you identify with the reasons I stated above.
[Re: 72Swinger]
#1577377
02/22/14 03:30 AM
02/22/14 03:30 AM
AlexP
Houston, Tx
Thanks, that may squeeze in behind the kick panel. I'm gonna have one in a month or so myself.
I wanted to mount it in my glovebox but my car leaks....well...like an old car. I'll end up mounting it in a semi-weather proof container somewhere by the AC box.
[Re: AlexP]
#1577378
02/22/14 04:07 AM
02/22/14 04:07 AM
haddixj
Shingle Springs Ca
I wonder if EFI source would build a system out of the new MS pro? That unit is designed to be able to get wet and mount in the engine compartment. I really like the kit form of MS that has come out. That should make it alot more popular with people
