Re: torque converter bolts keep comming loose [Re: rook440] #1576998
02/12/14 07:12 AM
02/12/14 07:12 AM
Arizona
Chris'sBarracuda Offline
Arizona
flex plate bolts wont stay tight ...I have fought this problem for years with a 8 bolt flex plate sfi approved ,3 passes and they are beating up the back of the block ,,,they are red locktighted and tight ,Jim VanZee is now having the same problem ...one guy years ago said buy "the wheel " but I never did Jim said some guys say it isnt the flex plate its the Harmonic ballancer ,,,whose got the real answer ,,,,???
I would say find the common things about both of your set ups.
If you have the same engine guy, that may narrow down the balancing.. Same converter company.?? T/F or Glide..
Chris..
Re: torque converter bolts keep comming loose [Re: Leigh] #1576999
02/12/14 10:53 AM
02/12/14 10:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bolts never come loose. They have no thread locker. Why are there hundreds of cars out there W/O locktite that have no issue? If they come loose with locktite there's a real problem. The only real cause that I can think of is harmonics whether it's a balance issue, detonation, or other. Oblong holes shouldn't matter,the bolt is not driving the plate,the clamp load is what holds it tight.
Doug
Respect your opinion...but if oblong holes do not matter then they would come from the factory that way...
Respect your opinion as well...but most factory holes are anything but perfect in size relationship to the fastener employed. And why would they spend more on an oblong shape anyway, if not needed? Factory stampings are about cost containment.
I'm not saying thats correct. It's the result of loose bolts, not the cause. Some GM flex plates have oval holes at 90* to each other from the factory. If an oval hole was an issue they wouldn't have ever done that.
Doug
Re: torque converter bolts keep comming loose [Re: Dunnuck Racing] #1577000
02/12/14 12:42 PM
02/12/14 12:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Ran into this last year after changing convertor in a customers car. The convertor fit fine on a 6 bolt crank but on an 8 bolt, the flexplate to convertor bolts hit the hub on the convertor before the bolts into the convertor were tight.
Look to marks in that area of the convertor from the bolt heads. Thin spacers between the two fixed the issue but we used longer bolts to ensure enough thread engagement.
I have absolutely seen this as a problem with several cars. The bolt heads are barely rubbing on the rounded part of the converter housing, and they will back out almost every run, or every couple runs.
I think its already been said here.
1) Check for interference of bolts/TC cover
2) Balancing/damper ( we have no idea on this one, only YOU know if the shop balanced it.Get the records from them and see if anything looks suspect)
3) I agree 100% with torquing the bolts everytime. A converter bolt SHOULD NOT need red loctite to STAY IN. Only to be a preventative safety measure.
My
RIP Monte Smith
Re: torque converter bolts keep comming loose [Re: CompWedgeEngines] #1577001
02/12/14 01:10 PM
02/12/14 01:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My
To go into detail a little further we had an aftermarket damper that looked great last year but the outer ring spun 180 degrees. Double check top dead center to see if the outer ring could be moving. An ATI damper is going on this years engine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: torque converter bolts keep comming loose [Re: pittsburghracer] #1577002
02/12/14 01:33 PM
02/12/14 01:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He is running a ATI damper but I would check 2 things..
check the zero and check the numbers on it to make
sure it fits his application(external or internal
balancing)... the only times I've seen where the bolts
came loose the balance was off or the trans was not
in alignment and needed offset pins... I've been
using the MP bolts forever and I use them twice then
put in new ones(mainly because the head will round
a bit)... I use a impact on them through the starter
hole but just give then a light rap a couple times
Re: torque converter bolts keep comming loose [Re: MR_P_BODY] #1577003
02/12/14 10:32 PM
02/12/14 10:32 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Like everybody else said and check to make sure the converter bolts aren`t bottoming out, i.e. too long, I had this problem that I kept cracking flex plates, turns out the bolts were one thread too long, we cut them , put loc tite on them , retightened them with an impact thru the starter hole ( Like Mr P body said) and haven`t had a problem since.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: torque converter bolts keep comming loose [Re: 11secdart] #1577004
02/12/14 10:57 PM
02/12/14 10:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Good call, another possibility.
Doug
Re: torque converter bolts keep comming loose [Re: 11secdart] #1577005
02/12/14 11:23 PM
02/12/14 11:23 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I re-read this entire thread, and nobody else mentioned bolts bottoming out as a possible cause. Were your bolts coming loose? That's the problem the OP is experiencing, not cracked flexplates.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: torque converter bolts keep comming loose [Re: DusterDave] #1577006
02/13/14 12:45 AM
02/13/14 12:45 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Sorry I just thought it was something else worth checking
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
