69 ignition and door keys #1576544
02/09/14 09:17 PM
02/09/14 09:17 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
My R/T is pretty much unmolested, if I give the ignition switch to a locksmith can he make a key, not a rekey but a key that would work in the switch and existing door locks?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 69 ignition and door keys [Re: AZ_A12_BEE] #1576545
02/09/14 09:30 PM
02/09/14 09:30 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Usually yes, expensive but yes.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 69 ignition and door keys [Re: astjp2] #1576546
02/09/14 10:55 PM
02/09/14 10:55 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Dave, there is a key code but I think you need a key to remove the ignition switch from the switch housing so that you can see the code. However, the same key code is stamped on the side of the door locks. He can use a door lock to make an ignition key but I think he has to know the 1969 Chrysler key codes? There is a lock smith who lurks on this forum that made some for Alaska A12's car that was shipped to Germany. He only charged $20. (Unfortunately, it didn't work but it would have helped if he had the lock to test it.) It would be better if you could get a replacement ignition key so that you can use your existing door locks because the repros do not fit very well. I bought a repro ignition and door lock set and they crimped my door because they were too tight when you tried to slide the spring clip in between the lock and the inside of the door. I ended up buying some used originals off of Moparts and they were a lot better.
Re: 69 ignition and door keys [Re: AZ_A12_BEE] #1576547
02/09/14 11:09 PM
02/09/14 11:09 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Every time I buy a Mopar I've had to have keys made or locks re-pinned.
I don't know why guys always say it's expensive???
I never paid more than 15-20 bucks.
Ron
Re: 69 ignition and door keys [Re: RoadRunnerJD] #1576548
02/09/14 11:15 PM
02/09/14 11:15 PM
Dreaming of the 808
Dreaming of the 808
Dave, there is a key code but I think you need a key to remove the ignition switch from the switch housing so that you can see the code. However, the same key code is stamped on the side of the door locks. He can use a door lock to make an ignition key but I think he has to know the 1969 Chrysler key codes? There is a lock smith who lurks on this forum that made some for Alaska A12's car that was shipped to Germany. He only charged $20. (Unfortunately, it didn't work but it would have helped if he had the lock to test it.) It would be better if you could get a replacement ignition key so that you can use your existing door locks because the repros do not fit very well. I bought a repro ignition and door lock set and they crimped my door because they were too tight when you tried to slide the spring clip in between the lock and the inside of the door. I ended up buying some used originayls off of Moparts and they were a lot better.
John, I can pull the ignition switch easier than a door lock but maybe I will pull them all. Is the key info on the broadcast sheet?
Re: 69 ignition and door keys [Re: RoadRunnerJD] #1576549
02/09/14 11:16 PM
02/09/14 11:16 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought the original key cutter from my Chrysler dealership years ago. There is a a number on the ignition that you can cut a key by.You have to have my book and cutter. Not sure about the doors. Not sure if you can see the number on a b body still in the switch housing or not. I don't think you can.
Re: 69 ignition and door keys [Re: fastmark] #1576550
02/09/14 11:31 PM
02/09/14 11:31 PM
Warrenton, VA
Warrenton, VA
If you have the book and the cutter, can you cut keys? Maybe you can help Dave... but I don't think you can release the ignition lock from the switch housing without a key. You can't push the retainer pin in unless you turn the key. You have to get the code off a door lock. The key cutter person really needs a lock to test the key because just cutting it from the code is not foolproof.
Re: 69 ignition and door keys [Re: RoadRunnerJD] #1576551
02/09/14 11:42 PM
02/09/14 11:42 PM
Dreaming of the 808
Dreaming of the 808
Are these originals?
Re: 69 ignition and door keys [Re: AZ_A12_BEE] #1576552
02/09/14 11:45 PM
02/09/14 11:45 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Dave don't know the answer but if they are E-Bay keys stay away.
The locksmith told me most E-Bay keys don't cut well.
I always buy mine from RT Specialties and bring them in and never had a bad cut.
Also most good Locksmiths may still have blanks to sell and cut for you.
Ron
Re: 69 ignition and door keys [Re: RJS] #1576553
02/09/14 11:50 PM
02/09/14 11:50 PM
Dreaming of the 808
Dreaming of the 808
Ron
Ron, thanks for the info, yes that pic was from eBay
Re: 69 ignition and door keys [Re: AZ_A12_BEE] #1576554
02/10/14 12:31 AM
02/10/14 12:31 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I have a limited number of original keys & have the ability to punch them as original with a EP ('69/E series primary) door/ignition code and ES ('69/E series secondary) trunk/glove box/console code.
Re: 69 ignition and door keys [Re: 6bblgt] #1576555
02/10/14 12:39 AM
02/10/14 12:39 AM
Dreaming of the 808
Dreaming of the 808
I'm going to need 6 sets, 2 each for the R/T, A12 and 500
Re: 69 ignition and door keys [Re: AZ_A12_BEE] #1576556
02/10/14 03:43 AM
02/10/14 03:43 AM
Oh
His and Her 69's Offline
Oh
How did you loose so many keys to different cars???
Just wondering.
David
Re: 69 ignition and door keys [Re: His and Her 69's] #1576557
02/10/14 04:36 AM
02/10/14 04:36 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
They are hot! LOL
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 69 ignition and door keys [Re: His and Her 69's] #1576558
02/10/14 04:36 AM
02/10/14 04:36 AM
Dreaming of the 808
Dreaming of the 808
Just wondering.
David
I might have the keys for the A12, but the. R/T and 500 were motorless bodies when I got them with no keys
Re: 69 ignition and door keys [Re: AZ_A12_BEE] #1576559
02/10/14 06:31 AM
02/10/14 06:31 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Here are the blanks I have that cover most of the '60s, I'm missing a trunk key that was used on some ("CB" - series codes) '64-'67 cars.
Re: 69 ignition and door keys [Re: 6bblgt] #1576560
02/10/14 06:49 AM
02/10/14 06:49 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
& a "ES" series trunk lock.
Re: 69 ignition and door keys [Re: 6bblgt] #1576561
02/10/14 06:58 AM
02/10/14 06:58 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Millions of key blanks have been manufactured & Chrysler used the same 1969 version for almost a couple of decades - like everything else over the years - quality has changed.
I believe the "A", "B", "other?" stamped on the OEM "Chrysler" branded keys is the manufacturer: "B" = Briggs & Stratton.
Re: 69 ignition and door keys [Re: 6bblgt] #1576562
02/10/14 08:09 AM
02/10/14 08:09 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That is the same stuff I have at the shop.
Re: 69 ignition and door keys [Re: 6bblgt] #1576563
02/10/14 01:28 PM
02/10/14 01:28 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
Very interesting,rumor has it that B/S made way more money on car keys in the 60s than they ever did on small engines!
