Is this possible? #1576376
02/09/14 02:08 PM
02/09/14 02:08 PM
Newtown, CT
70ucode Offline OP
70ucode  Offline OP
Newtown, CT
I was at mopars at Englishtown several moths ago and made a couple of passes. I red lighted on the first pass then on the second pass ran alone and my time slip showed 11.70 at 114mph. Car number and lane number are correct. I just finished this car so it was the first time at the track. My car is a 70 cuda 4speed Dana with 3:54 gears. BF Goodrich T/A on 15x7 ralleys. Engine was rebuilt mostly stock 10.5-1 Pistons, Mr Six-Pac Cam, Good valve job, TTI exhaust with manifolds. On the engine dyno it produced 426hp@ 5400 and 523ft lbs TQ at 2300rpm. Is 11.70 possible with those specs? Seems off to me. Did I have a great run? Or is it more likely that there was a mistake. Love to hear you thoughts. I plan to try again at Muscle Palooza in spring. John
Re: Is this possible? [Re: 70ucode] #1576377
02/09/14 02:20 PM
02/09/14 02:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Post all of your run times, red light or not.
Give us for each run:
60' time
660' time
660 mph
1/4 mile et
1/4 mile mph.
for each.
What was the weather like on the day you ran?
Re: Is this possible? [Re: BSB67] #1576378
02/09/14 02:38 PM
02/09/14 02:38 PM
Newtown, CT
70ucode Offline OP
70ucode  Offline OP
Newtown, CT
Ok. Will do. Unfortunatley, I only have two. The first one is all zeros and the run in question I have at work. I will post it tomorrow. John
Re: Is this possible? [Re: 70ucode] #1576379
02/09/14 04:12 PM
02/09/14 04:12 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Doesn't sound right,but cars seem to run unbelievable numbers in the northeast compared to here. Also 523ft/lb at 2300?
Re: Is this possible? [Re: 70ucode] #1576380
02/09/14 09:51 PM
02/09/14 09:51 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I guess it depends on the air that day, but unless you had a very good 60 foot from the BFG T/A's... It is tough to run 11.70's??
Bob K's 440/6pk 69 runner goes 12.10's to 12.20's. And that car is really sorted out.
I am interested to see the incrementals from the run.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Is this possible? [Re: cudabin] #1576381
02/09/14 11:09 PM
02/09/14 11:09 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
John
Unless your 60' was in the mid 1.60s which I doubt with BF G tires it does not seem possible.
Your MPH should have been close to 120 for that ET
Re: Is this possible? [Re: 70ucode] #1576382
02/09/14 11:23 PM
02/09/14 11:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No,You would be hard pressed with those tires to get into the 12's.
My wifes 360 4 speed Challenger makes similar power numbers. With T/As and a 3.55 it's been 13.20@107. With slicks and a 4.30 it's been 12.50@110.
Doug
Re: Is this possible? [Re: dvw] #1576383
02/10/14 03:25 AM
02/10/14 03:25 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Hey John, I'll come over and take it for a ride and let you know
Re: Is this possible? [Re: GTX MATT] #1576384
02/10/14 06:29 PM
02/10/14 06:29 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
The Speed sounds right for that ET. My 56 runs a consistent 11.72 at 114 mph.. with a 1.60 60 ft... 3700 lbs w 3/55 gears...
Re: Is this possible? [Re: 70ucode] #1576385
02/11/14 02:49 AM
02/11/14 02:49 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sounds good. I have ran 11.70's with a bit more MPH (119), but my 60' times are not very good.
Re: Is this possible? [Re: 451Mopar] #1576386
02/11/14 03:56 AM
02/11/14 03:56 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
ET sounds correct for the speed, for a car with bite. Don't see how you could get deep into the ll's at that speed on street tires, though. With Radial T/A's and 3.54 gears, I'd expect 11.70 to need nearly 120mph. By comparison, my car goes 11.80's @ 113, but thats on ET Street radials with 3.91's riding on Calvert suspension that lets me mash the floor right out of the hole. I typcially short time @ 1.63. For your combo to go 11.70's, if I'm guessing it at around 3650lbs with you in the seat, you would need to be knocking on the 500 hp door to get to 114.
I'm rooting for you, but something seems a little fishy (no pun intended). I admit that I'd have to see a backup slip to feel confident about that number. Only one thing to do, I guess....
Re: Is this possible? [Re: 70ucode] #1576387
02/11/14 04:07 AM
02/11/14 04:07 AM
gregsdart Offline
gregsdart  Offline
I don't see it as possible. The tires for one, won't hook up that well. As an example, I have an 06 GT mustang, Saleen blower with 7psi boost making about 480 at the crank. The weights would be close, your car to mine. The Mustang only pulled a 2.00 60 ft, went 12.42 at 115 mph. Most 7 psi blown mustangs like mine put out about 470 to 480 hp at the crank, 420 at the tires.
Re: Is this possible? [Re: gregsdart] #1576388
02/11/14 10:04 PM
02/11/14 10:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Hey John, I was thinking about this, and your trap speed is in line with the pure stock six pack cars, and you've got some light head work and bigger tires. I don't think it's totally impossible if you pulled off a decent 60 foot time. The pure stock guys usually run 4.10s but with your brutal torque at 2300 rpm it may not have minded the 3.54s much.
Re: Is this possible? [Re: GTX MATT] #1576389
02/11/14 11:25 PM
02/11/14 11:25 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Probably not a great comparison.
Re: Is this possible? [Re: 70ucode] #1576390
02/11/14 11:41 PM
02/11/14 11:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Along with that time slip details, I have a few other questions: 1) What does your car weigh. 2) Give us the date you were at the track. 3) Give the details of you 10.5:1 CR, (is it simply the 2355 piston or something more sophisticated than that?) and 4) was the 426 hp on the dyno with your exhaust manifolds, or headers?
Re: Is this possible? [Re: BSB67] #1576391
02/12/14 12:31 AM
02/12/14 12:31 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
One might not think, but didn't you trap 108 with the 272/272, manifolds, six pack, and 2.25 inch pipes with 3.23s?
Hes running Bob Ks cam
Re: Is this possible? [Re: GTX MATT] #1576392
02/12/14 03:09 PM
02/12/14 03:09 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
I have a few time slips with incorrect numbers.....
One says I went 12.26 @ 303 MPH
One more says my 60' was 1.04 on a 10.51 pass. (The car would have put the rear bumber on the ground, or broke in half with a 60' like that)
I am guessing there is something wrong with the time slip......
Like said before need to see all the numbers to prove it.
If not that is one darn good running "warmed over" 440 street car!!!!
Re: Is this possible? [Re: GTX MATT] #1576393
02/12/14 04:20 PM
02/12/14 04:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Right.
My point was to whom the results should be compared. I just don't think the quickest of the PSMCDR A12 guys is a good comparison. And actually, I have not ruled out anything yet, although I am leaning in the same direction as most everyone else.
Depending on the answers to the questions I've asked, I could see the car trapping at 111 mph. And if the car has a true street tire and factory suspension it is really hard to get them to 60 ft much better than 2.0 sec. But that is a lot of guessing and assumptions on my part.
Re: Is this possible? [Re: BSB67] #1576394
02/12/14 05:32 PM
02/12/14 05:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Car has to weigh at least 3800 lbs. Do the math, 426 HP is not going to go 114@3800. At best 110-111. And I'll bet it's closer to 3900-4000lbs. Am I correct?
Doug
Re: Is this possible? [Re: BSB67] #1576395
02/12/14 06:30 PM
02/12/14 06:30 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Right.
Don't get me wrong, I don't think that it's likely or that would be easy, but I do think its possible. The Pro Tru Wisecos that John is running are 625 grams a peice, so they're fairly light. As I recall hes running 255s or 275s out back. Promax is reputable, and he has headwork that the pure stock guys don't have. Depending on how much bowl work was done they may flow 250-260 cfm or so. He is also running the Edelbrock intake, not the Chrysler cast iron intake.
