Pivot shaft and lower control arm #1576329
02/09/14 07:08 AM
02/09/14 07:08 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
According to the service manual when install the pivot shaft and LCA the pivot shaft nut should only be finger tighten BUT should the pivot shaft be botten out in the mounting hole (k-member).
Outhervise it must be impossible to mount the torsion bars locking clips in the anchor.
Hope you guys understand the question, I'm Swedish ha ha.
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
Re: Pivot shaft and lower control arm [Re: Snoddas] #1576330
02/09/14 07:48 AM
02/09/14 07:48 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Yes. As I understand it, it can be slightly tighter than finger tight, but not so tight that the bushing can't move. That's so the bushing can rotate when the car is taken off hoist so weight is on wheels. Only after weight on wheels should pivot shaft nut be torqued down. That way, bushing is not twisted and destroyed when car is lowered off hoist.
Re: Pivot shaft and lower control arm [Re: MoparMarq] #1576331
02/09/14 08:06 AM
02/09/14 08:06 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Thanks man.
Re: Pivot shaft and lower control arm [Re: MoparMarq] #1576332
02/09/14 01:46 PM
02/09/14 01:46 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Also, the strut rod nuts should be loose at the K frame. You need to set the ride height before tightening any of these nuts. Per the service manual.
