Head bolt locations- small block #1576067
02/08/14 08:15 PM
02/08/14 08:15 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Anyone by any chance have these dimensions drawn up? Maybe on a dxf file or a website with them online? If not ill just have to measure the old fashioned way.. thanks in advance.
Re: Head bolt locations- small block [Re: Hot 340] #1576068
02/08/14 10:29 PM
02/08/14 10:29 PM
Delray beach, Florida
P
Performance Only Offline
P
I don't know if it matters to you or not, but the head bolt holes and dowel pin holes are all measured and spaced from the datum hole in the pan rail.
What's a dxf file?
machine shop owner and engine builder
Re: Head bolt locations- small block [Re: Performance Only] #1576069
02/10/14 07:43 PM
02/10/14 07:43 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Wouldnt have to have been from that hole by the pan, just in relation to everything on the deck... But i got them the old fashioned way. A dxf file is a type of file commonly used in autocad drawings.
