valve body usage question.
#1575934
02/08/14 06:11 PM
02/08/14 06:11 PM
Posts: 1,191 imperial mo.
stickman
imperial mo.
What year trans will a 1970 727 valve body work in. Would it work in a 67 or 68? Thanks Guys
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: valve body usage question.
[Re: stickman]
#1575935
02/09/14 12:04 AM
02/09/14 12:04 AM
RapidRobert
I would think so but just consider this a BTT & wait for Kunkel to chime in
[Re: dvw]
#1575937
02/09/14 11:38 AM
02/09/14 11:38 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
IIRC the combs for VBs are different in early years.I believe they changed in 68 or 69.Rocky
Chrysler Firepower
[Re: stickman]
#1575938
02/09/14 05:38 PM
02/09/14 05:38 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A '70 VB is correct for only '68-'70 but it will work in a '66-'67.
'71 and later cases have a different accumulator fluid circuit.
[Re: 451Mopar]
#1575941
02/10/14 06:31 PM
02/10/14 06:31 PM
John_Kunkel
Rio Linda, CA
The rooster comb problem only arises if you try to swap one into the incorrect VB casting, for a complete VB swap (like the OP) the 3-prong rooster comb will work with the '64-'68 single-prong switch but not vice-versa.
