Re: AN fittings..what brand do you use
[Re: 70dusterjohn]
#1575818
02/08/14 02:07 PM
02/08/14 02:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the Summit brand... any of them cost... these Summit ones are just a little less pricey... try plumbing a dry sump.. that will get real pricey even with the less pricey ones
[Re: dartman366]
#1575819
02/08/14 02:14 PM
02/08/14 02:14 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Over on the EBAG, there is a company called Professional Products that sells a 5 pack of fittings, in all sizes and shapes for a really killer price.. So me, being Mr Tightbehind, bought everything I needed for my last motor build and saved a ton of money.. But today, I am slowly replacing the fittings because after a short period of time, the swivel part of the fitting stopped swivelling.. and we all know what a pain it is to remove a fitting only to have the entire hose spins too.. So I saved a dollar to waste a dollar..
[Re: Jeepmon]
#1575820
02/08/14 02:20 PM
02/08/14 02:20 PM
Triple Threat
Renton Washington
If you mix brands of hose and fittings sometimes they dont play well together. My entire fuel system is Earls Pro Lite 350 hose and Earls fittings. The tranny cooler lines are stainless braid from summit with their fittings.
If you dont mind having a summit or jegs logo on them, i've had no issues with their house brands.
[Re: Triple Threat]
#1575821
02/08/14 02:32 PM
02/08/14 02:32 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I've had good luck with the summit brand. Every now and then you get a stubborn swivel, but I've had that with a couple different brands.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Joes66dart]
#1575824
02/08/14 04:45 PM
02/08/14 04:45 PM
Posts: 1,019 Finland
mafo
Finland
I bought some cheap chinese fitting here locally and I can t see any difference compared with the ones that summit or jegs sells? probably made in the same factory , anyhow they worked great on my transmission cooler
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: AndyF]
#1575830
02/08/14 09:34 PM
02/08/14 09:34 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
The water manifold blocks that I sell can be fitted with hose fittings rather than AN fittings. Then you just cut the rubber lines to size and use a hose clamp. Shouldn't cost more than a few bucks to do all the plumbing this way.
I'd like to see more of your set up with these. Looks cool! I'd like to redo my turbo set up and move it front and center. If that big ol pump was gone it would make life way easier..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#1575831
02/09/14 02:10 PM
02/09/14 02:10 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I buy the cheap 5 packs off ebay. Its nice having extras. Ive never had any problems with them.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1575832
02/09/14 05:42 PM
02/09/14 05:42 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
"If it's not show quality you are after and just fluid conveyence...then try the industrial hyd hose/fitting route."
So true. One of my sons is a heavy equipment mechanic, and we go to his employer and get those all the time. Most all heavy equipment uses hoses with those ends. Heck, they can probably make you the whole hose for the price of a couple of Earl's fittings.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
