AAR HOOD QUESTION #1575676
02/08/14 12:59 AM
02/08/14 12:59 AM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
Do the AAR's use the hood align wedges that mount on top of fender ??
Also..
Do they use the pop up spring thats mounted on the radiator support??
Re: AAR HOOD QUESTION [Re: IB-CUDA] #1575677
02/08/14 01:05 AM
02/08/14 01:05 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Yes on the wedges, no on the spring
Careful, your character's showing!
Re: AAR HOOD QUESTION [Re: mopar346] #1575678
02/08/14 01:16 AM
02/08/14 01:16 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The original hoods have drop ears that align with the wedges. Some of the reproductions I have seen do not.
Re: AAR HOOD QUESTION [Re: Alaskan_TA] #1575679
02/08/14 01:29 AM
02/08/14 01:29 AM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
Thanks guys.. Its a AAR fiberglass Reproduction so i'll go look for the drop ears..
Should I run the repo AAR hinge springs or just go with-out like i currently am... The prop rod i have is getting old already
Re: AAR HOOD QUESTION [Re: IB-CUDA] #1575680
02/08/14 08:35 AM
02/08/14 08:35 AM
mopar346 Offline
mopar346  Offline
I think the aftermarkets are re-enforced better so a light spring doesn't warp them. If you run without make a couple hook that goes from spring attaching hook/groove to hook/groove in the length of the hinge when open. You can even paint it to match.
