99 Ram Transmission Shifting Issue (strange) #1575640
02/07/14 11:35 PM
02/07/14 11:35 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
My transmission is sometimes holding second gear, refusing to shift into third until I either A: let off the gas and quickly cycle the transmission into neutral and back to drive (works every time), or b: rev the engine over 4500 rpm and then let off the gas (works sometimes).
There is another component to this, it only seems to do this during extreme cold. I experienced it once on a subzero day in my old home, now I have moved further north and subzero is common this time of year.
I'm planning on changing the filter/fluid this weekend, anything else I might look for while I'm under there?
71 Charger R/T 67 Barracuda 99 Ram Sport 09 Challenger R/T
Re: 99 Ram Transmission Shifting Issue (strange) [Re: BCSharp] #1575641
02/07/14 11:45 PM
02/07/14 11:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Ask John Kunkle who is a member here.He knows those trans well.
Nautilus Racing-
Re: 99 Ram Transmission Shifting Issue (strange) [Re: Chris2581] #1575642
02/08/14 12:47 AM
02/08/14 12:47 AM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Typical problem for the Rams of that year. They had a problem with a lip seal shrinking. Only fix is to rebuild it.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 99 Ram Transmission Shifting Issue (strange) [Re: Prodart440] #1575643
02/08/14 01:10 PM
02/08/14 01:10 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Front clutch seals need to be replaced.
Re: 99 Ram Transmission Shifting Issue (strange) [Re: teflon] #1575644
02/08/14 08:47 PM
02/08/14 08:47 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
Thanks guys, heard from John Kunkle and talked with a transmission specialist I know from back home. They both seem to agree with you. At least it's still functional, just not very automatic! Should let me limp it along for a little bit until I have time to tear into it. Its at over 150k miles, I was thinking an overhaul was coming pretty soon.
Re: 99 Ram Transmission Shifting Issue (strange) [Re: BCSharp] #1575645
02/09/14 04:48 AM
02/09/14 04:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They are right as I used to see it alot at the Dealer I worked for. We had an updated front drum for many models also. Ron
Re: 99 Ram Transmission Shifting Issue (strange) [Re: Prodart440] #1575646
02/09/14 03:52 PM
02/09/14 03:52 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Yep while my Trucks do not do it my Grand Cherokee does. It's been acting like that when it's cold out for over 3 years and hasn't hurt anything. Once it's warm the seal expands and shifts smoothly....I will rebuild it only when something critical happens so far though no "other" problems with the trans....
