3418901 Cast Piston? #1575638
02/07/14 11:13 PM
02/07/14 11:13 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
these std pistons are from a 1968/70 318cid engine, I've looked but don't find this number in the lists I've located.
What do I have? Pin height?
Re: 3418901 Cast Piston? [Re: MO_PA] #1575639
02/07/14 11:52 PM
02/07/14 11:52 PM
You could set the piston face down on your kitchen table then extend the pin out a bit just past the piston outer edge then measure from the table up to the the pin then add in .492"
