Rust Remover Recipe (revisited) #1575437
02/07/14 03:24 PM
02/07/14 03:24 PM
Russ H. Offline OP
Russ H.  Offline OP
I recently read the old post about home made rust remover recipes and am wondering if there are any new developments or formula's proven to work.
Also, it seemed that a major issue with the vinegar/lemon juice/salt formula was neutralizing the acid once the parts were cleaned. Has anyone tried running newly cleaned parts through a cycle in a dishwasher. Other than a possible domestic squabble, would this be an effective way to neutralize the acidic residue?
Russ
Re: Rust Remover Recipe (revisited) [Re: Russ H.] #1575438
02/07/14 03:44 PM
02/07/14 03:44 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
most dishwasher soap is going to be corrosive on soft metals and anything ferrous will flash rust too quickly.
Re: Rust Remover Recipe (revisited) [Re: 135sohc] #1575439
02/07/14 04:00 PM
02/07/14 04:00 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
just use evaporust and rinse in varsol.
Re: Rust Remover Recipe (revisited) [Re: Russ H.] #1575440
02/07/14 04:30 PM
02/07/14 04:30 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Russ
Evaporust is also acidic. Not as much but still it is not ph neutral.
The only "major issue" seems to be with those who poo-poo the non-commercial solution.
After treating the parts in the vinegar/lemon juice/salt I just rinse the pieces thouroughly in water. Drop them in a bucket of clean water and soak for a minute. Thats it. Really. No problems.
Spend a lot more money on the commercial products if you want to but I make this stuff in 5 gallon buckets for under $10 and it lasts a long time.
Re: Rust Remover Recipe (revisited) [Re: nomore65BelvJim] #1575441
02/07/14 05:31 PM
02/07/14 05:31 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Just out of curousity what is the ratio for this solution?
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Rust Remover Recipe (revisited) [Re: sixpackbee] #1575442
02/07/14 05:42 PM
02/07/14 05:42 PM
Russ H. Offline OP
Russ H.  Offline OP
Here it is.....
1/2 gallon of white vinegar
6 or 8 oz. of concentrated lemon juice
1/3 cup of table salt
Thoroughly mixed. That's all there is to it.
Re: Rust Remover Recipe (revisited) [Re: Russ H.] #1575443
02/09/14 12:23 PM
02/09/14 12:23 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Russ
I used the salt/vinegar (HCL acid) recipe to remove rust on my '65 Satellite project. To neutralize the acid, I used Arm&Hammer Baking Soda mixed in some water. Then used hot hot water for the final rinse, and towel-dry and compressed air dry the part.
Best,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Rust Remover Recipe (revisited) [Re: 67SATisfaction] #1575444
02/10/14 02:13 PM
02/10/14 02:13 PM
SE Wisconsin, USA
RP's R/T's Online content
RP's R/T's  Online Content
SE Wisconsin, USA
OK, I've heard of this before, but a few questions:
- How long do you leave the product in the solution? I realize it depends on the part and on the extent of rust, but generically-speaking, is this a week of soaking, a day?
- how long does the solution stay useable? If it seems weak, is the answer to add more lemon juice? or what typically is item that weakens?
- Will the local cat think it's a big margarita? Just kidding.
Re: Rust Remover Recipe (revisited) [Re: RP's R/T's] #1575445
02/10/14 05:33 PM
02/10/14 05:33 PM
The temperature of the solution seems to have an effect. The warmer it is the faster it seems to work. I've had parts submerged soaking in it for 24-36 hours when warm(the shackle bracket above was 24-36 hrs) 48-72 hours or so when cool. I dont bother trying to spike the mix to rejuvinate it. Its so inexpensive I just dump it and make a fresh batch. If you take the time to thouroughly clean the part of dirt, grease, undercoating, etc. it cleans up faster and the solution lasts longer. I've had the paint removed by the mix on some parts like fender braces.
It doesnt seem to "go bad" over time, just with use. I've used a 3-4 gallon batch for dozens of parts; spring hangers, shackles and brackets, nuts, bolts, exhaust hangers, etc. over the course of 9 months and it worked well.
You will likely see sediment forming in the bottom of the bucket with a lot of use.
Re: Rust Remover Recipe (revisited) [Re: nomore65BelvJim] #1575446
02/11/14 11:58 PM
02/11/14 11:58 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
VERY interesting thread.
I have a question. Will this solution have any adverse affects on chrome?
The reason I ask is that I have a set of road wheels that are in nice shape that I want to restore. The chrome spokes are perfect, but the backsides have very minor surface rust. I don't want to blast the backsides as it would remove any plating.
Ever use this solution on chrome parts?
I've read about using oxalic acid to dissolve rust, but am also afraid it will affect or discolor the chrome.
Re: Rust Remover Recipe (revisited) [Re: bill440rt] #1575447
02/12/14 01:16 AM
02/12/14 01:16 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Definition of an acid: a solution that reacts with metals.
Vinegar and lemon juice are both weak acetic acids. Maybe they will react with iron oxide more quickly that with chrome, but the game you will be playing is this: will my rust go away before my chrome (or nickel) gets ruined?
It may be that the backside of your wheels is nickel plating on top of copper plating, and the front side is copper-nickel-chrome plating. That does not look like bare steel in the photo.
(Chrome will not plate on steel but will plate on nickel. Nickel will not plate on steel but will plate on copper. Copper will plate on steel. That's why "chrome plating" is actually copper-nickel-chrome plating.)
I would not put acid on nickel or chrome except very carefully after experimenting. Personally I would try chrome polish on the backside first. Do no harm.
Re: Rust Remover Recipe (revisited) [Re: kentj340] #1575448
02/12/14 11:29 AM
02/12/14 11:29 AM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Not sure how the factory would do a 3-step plating process on the front and only a 2-step on the back?
On '69-up road wheels it looks like the centers were plated first, then dropped in the hoop & welded, then the wheels were painted.
In some online research I found this old thread on a BMX forum where they were restoring rusty chrome plated bike frames with oxalic acid (it's a l-o-n-g thread):
http://www.vintagebmx.com/community/index.php?showtopic=4004702&st=0
I'm still hesitant to drop a wheel into this solution, so that's why I'm curious about this vinegar/salt/lemon mixture.
Sorry for the hijack, but this thread is perfect timing.
Anyone on here use either of these solutions on chrome parts?
Re: Rust Remover Recipe (revisited) [Re: bill440rt] #1575449
02/12/14 01:55 PM
02/12/14 01:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This is not true. Nickel will absolutely plate on steel.
The triple plate chroming of copper, nickel, chrome is only done on high end plating jobs. The copper is actually used as a filler and in the case of pitted metal it would be sanded down and replated in copper until the final copper dip showed no imperfections. Only then would it be nickel then chrome plated. The nickel is actually the coating that provides the color, the chrome is sort of like a clear coat and the color would vary with the underlying tone. If you look at early Corvettes, you'll notice the bumpers have a gold or yellow tint to them - possibly from skipping the nickel process (I've never wondered enough to find the reason why).
As I said, lower end chroming jobs will often skip the copper because its expensive and labor intensive. Not only do they have to buff the steel surface but once dipped the copper also needs to be buffed. So the copper step is skipped and the part just gets nickel and chrome.
That said, I would imagine that back in the day many production vehicle bumpers received only a nickel and chrome finish. Looking at the AMD repro bumpers, I think that's all they get too.
You can usually easily see the difference. Done properly, a triple plated piece will be perfectly smooth as the soft copper can be buffed to a finer finish whereas the harder steel will usually show the marks right through the nickel and chrome.
FWIW nickel provides a nice durable finish over steel and is something that can be done in your own shop. There are loads of you-tube videos.
With regards to the OP's wheel issue, I doubt those would be triple plated. Most likely nickel/chrome. I that solution I seriously doubt the chrome will be harmed. To remove chrome you need a strong caustic soda solution - like Drano !!
Sorry to take this off the original "rust removal" topic but some things stand to be corrected.
Re: Rust Remover Recipe (revisited) [Re: Stanton] #1575450
02/19/14 08:31 PM
02/19/14 08:31 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
