Pulling motor in 77 van
#1574828
02/06/14 11:56 AM
02/06/14 11:56 AM
Posts: 836 Up a holler, down a crick
booger
I've got a motor home here built on a 77 1-ton van chassis with a 360 auto drivetrain. It's smoking like a chimney after it runs for a few minutes, and even if it's just the valve seals, it looks like it'd be a nightmare to work on them with the motor in the chassis. Plus, a 77 model motor is just about guaranteed to have bad valve seals, so if I just replaced those and it turned out to be the rings, I'd still end up pulling the engine. So it seems like anyway I look at it, the engine needs to come out to fix the problem. I've found conflicting stories on how to get the engine out. Some say pull the front end off the van and come through the front, others say it'll come out through the passenger door. Either way it goes, I'll probably pull the trans first, so I have one less thing to wrestle with while the engine's on the hook. I wondered if anyone with experience would let me know what they found to be the best way to do it? Thanks
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: Pulling motor in 77 van
[Re: rustbuckett68]
#1574831
02/06/14 03:00 PM
02/06/14 03:00 PM
booger
Thanks for the replies. The FSM pages will help, if you get a chance.
Sounds like what I need is a plate to bolt in place of the carb, then hook the cherry picker directly to that with no chain.
Now if it would just warm up. The vehicle won't fit through my garage door so it'll be done outside.
[Re: booger]
#1574836
02/06/14 05:54 PM
02/06/14 05:54 PM
Guitar Jones
I've done a bunch of these, getting it out the passenger door can be done but it's a real mess. Pulling the front end is easier really. I pulled the compressor, alternator and p/s pump off first, then pulled the intake, stretch a chain across the heads intake bolt holes and attach the crane to that. You need all the room you can get there. Raise the front end so the boom is as level as possible with the engine lifted. The trans can stay in but must be supported with a floor jack or something.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: poorboy]
#1574838
02/06/14 08:22 PM
02/06/14 08:22 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1574839
02/06/14 11:11 PM
02/06/14 11:11 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Out the front. If you are one of those 'toss all the bolts in a coffee can' guys, this is a good one to learn to remove the bolts and part, then put the bolts WITH the part. This is also a GOOD one to pressure wash first! Bumper, grille, A/C, radiator and brackets, accessories, carb and dist., jack that bad boy up so the boom is flat on the intake (or remove and have it under that level). Then pull the exhaust and trans stuff, motor mounts then lift it until the boom is just touching the body, slide forward and out. Some have suggested pulling the oil pan too, but I didn't (small block).
[Re: RodStRace]
#1574840
02/07/14 12:35 AM
02/07/14 12:35 AM
booger
Looks like out the front is the way to go My shoulder is already aching just thinking about it. Buy stock in Advil. Wish I had a son, I'd make him do it Thanks for the info
[Re: booger]
#1574841
02/07/14 10:42 AM
02/07/14 10:42 AM
Guitar Jones
Thanks for the info
I use Aleve, works better and lasts longer.
Oh and the Thermo-Care heat patches are a big help too.
