Comp 829 safe open pressure limit? #1574786
02/06/14 04:03 AM
02/06/14 04:03 AM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline OP
Ohio Joe  Offline OP
Can a Comp 829 roller lifter safely handle 800 lbs open pressure ? This is the first time I have used a roller cam and I want it to be right. I will more than likely go with PAC 1326 springs and 3/8 Smith Brothers pushrods. My question is can the lifters handle it.
66 Dart GT " Rat Racer"
Re: Comp 829 safe open pressure limit? [Re: Ohio Joe] #1574787
02/06/14 04:10 AM
02/06/14 04:10 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am using the 99550-16 cranes...on my 572 hemi. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Comp 829 safe open pressure limit? [Re: Ohio Joe] #1574788
02/06/14 05:29 AM
02/06/14 05:29 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm using the Comp Roller lifters, but only 700# open pressure with PAC1325 valve springs 0.714" lift cam, 1.950" install height (about 275# seat pressure.) I may have around 500 miles street/strip on them, and I usually shift around 6,500 RPM. I originally used 0.083" 3/8" pushrods, but upgraded to 0.120" wall.
Re: Comp 829 safe open pressure limit? [Re: 451Mopar] #1574789
02/06/14 05:40 AM
02/06/14 05:40 AM
Ohio Joe Offline OP
Ohio Joe  Offline OP
This is race only, 470 low deck. I don't have all the info on cam handy but I believe it's .705 lift.
Re: Comp 829 safe open pressure limit? [Re: Ohio Joe] #1574790
02/06/14 06:09 AM
02/06/14 06:09 AM
Arizona
Chris'sBarracuda Offline
Arizona
I'm using this exact spring and 829's..
Also Smith .120" wall 3/8" pushrods.
http://www.racingsprings.com/1200%20Series/PAC-1228/item/158
90 runs on my B1 so far..
Hopefully they last, but I have spares.
Chris..
Re: Comp 829 safe open pressure limit? [Re: Ohio Joe] #1574791
02/06/14 12:56 PM
02/06/14 12:56 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I have used them @ 1000# open and 8500 RPM had them rebuilt by comp every year to be safe.
Re: Comp 829 safe open pressure limit? [Re: Ohio Joe] #1574792
02/06/14 03:12 PM
02/06/14 03:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use them in street cars
Re: Comp 829 safe open pressure limit? [Re: Al_Alguire] #1574793
02/06/14 07:55 PM
02/06/14 07:55 PM
Dyno1 Offline
Dyno1  Offline
I have used them over 5 years, no problems in my SS/AH car. Dyno
Re: Comp 829 safe open pressure limit? [Re: Dyno1] #1574794
02/06/14 11:20 PM
02/06/14 11:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use them w/comp 996 springs. 275/775psi at .800". 90 passes so far lash has stayed consistent. I run a tight lash roller, fairly aggressive with T&D rockers and trend 7/16" x .160" pushrods.
Doug
Re: Comp 829 safe open pressure limit? [Re: dvw] #1574795
02/07/14 02:31 AM
02/07/14 02:31 AM
Ohio Joe Offline OP
Ohio Joe  Offline OP
Thanks everyone, sounds as if there should be no troubles.
Re: Comp 829 safe open pressure limit? [Re: Ohio Joe] #1574796
02/07/14 12:51 PM
02/07/14 12:51 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Id use Isky EZ Rolls....bushed lifter bores as well..but thats me...
I havent used an 829 in a while, I hope they redesigned how the pushrod seat is retained in the lifter body...The ones I had here used only an o ring to retain the seat...Some actually came out of the lifter just from the oil tension when pulling a pushrod out...on a fully assembled engine...
MB
