need info from someone on front end fo a duster #157474
11/26/08 08:45 PM
11/26/08 08:45 PM
minnesota ,usa
440dakota Offline OP
minnesota ,usa
im looking for some measurements on the front end of a duster trying to take over someones unfinnished tube chassis car so ineed the hub to hub and the wheel base email pat pl831@wmconnect.com thanx
Re: need info from someone on front end fo a duster [Re: 440dakota] #157475
11/26/08 09:00 PM
11/26/08 09:00 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
You mean the wheel base front to center? Its 108, front hub to hub will be hard to measure due to the alignment. Is the front end width what ya trying to figure out?
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
