BEST EFI SYSTEM FOR 512 STROKER?
#1574347
02/05/14 01:51 AM
02/05/14 01:51 AM
Posts: 441 Uranus
strokerchall
Uranus
Estimating 600 plus hp/tq
once you've stroked it,you'll wish you stroked it sooner
Re: BEST EFI SYSTEM FOR 512 STROKER?
[Re: strokerchall]
#1574348
02/05/14 10:56 AM
02/05/14 10:56 AM
Posts: 1,883 Northern OH
rapom
Northern OH
Fast 2.0 system if you want a turn key setup that learns itself.
What Dragula is asking is important. If the cam duration is over 250 degrees at .050 then you can't use most self learning systems and have to get a programmable system which fast and others also sell.
[Re: strokerchall]
#1574357
02/11/14 02:28 AM
02/11/14 02:28 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
rb 440 block,eddy rpm's,hughes cam,HEH3237BL INTAKE 232 EXH 237
What pistons? I'm using the 440 Source 4.25" stroker kit for a 0.030" over 440 (505 cid.) The pistons are the 17cc dish KB ICON-839. I'm using mildly ported 84cc Stealth heads, so compression is around 10.3:1. The cam is a Comp Hydraulic Roller XR286HR-10, 236/242 duration @ 0.050, 0.581"/0.578" using 1.6:1 rocker arms.
The cam seems pretty tame in my engine.
