Hemi single 4 intake manifold question #157426
11/26/08 06:36 PM
11/26/08 06:36 PM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
So I've got a leak from my intake manifold. Problem is i can't seem to remove the back two bolts on the intake manifold due to the fact the bolts are almost touching the manifold and i can't put a socket on it nor is there enough room to put a wrench on it. ANy suggestions???
Re: Hemi single 4 intake manifold question [Re: Slipknot440] #157427
11/26/08 06:59 PM
11/26/08 06:59 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
crows foot wrench, basically a 90 degree bent wrench to go from the top. After you fix this, mine has the hex screws and I use an allen head to install. that is a much smaller head
Re: Hemi single 4 intake manifold question [Re: Slipknot440] #157428
11/26/08 10:38 PM
11/26/08 10:38 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Are you talking about the back of the intake (3 bolts the thread into the block)? I made the mistake of putting bolts in there (loose) to hold the end seal. I couldn't get the middle one in (I think it's impossible). I had to use a mirror, an open end wrench, and I had to hold my mouth a certain way to get them out.
After that I just use the Right Stuff front and back and never had problems with leaks.
Re: Hemi single 4 intake manifold question [Re: torkrules] #157429
11/26/08 11:30 PM
11/26/08 11:30 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I think 66-67 used to be bolted on the back and front but the manifolds were easy to crack. 68 and up are not bolted to the front and rear rails...
Re: Hemi single 4 intake manifold question [Re: RoadRunnerJD] #157430
11/27/08 07:51 AM
11/27/08 07:51 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
They changed to spring pins after that problem. I don't use anything anymore. Just Right Stuff front and back-no leaks.
Re: Hemi single 4 intake manifold question [Re: torkrules] #157431
11/27/08 11:56 AM
11/27/08 11:56 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
You can also try a thinwall socket..
