VIN plate help #1574197
02/04/14 11:01 PM
02/04/14 11:01 PM
Lon207 Offline OP
Lon207  Offline OP
I recently acquired a 1947 dodge pickup. I also have a VIN plate. The number on the plate is serial 81120282. Does this plate go with the 47? thanks in advance
Lon
Re: VIN plate help [Re: Lon207] #1574198
02/05/14 02:37 AM
02/05/14 02:37 AM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
It's in the ballpark. Looks like a 1945 WC 1/2 ton
Re: VIN plate help [Re: Lon207] #1574199
02/05/14 11:47 AM
02/05/14 11:47 AM
OHIO
THE GLASS MAN Offline
OHIO
Lon
Where is the vin plate? On your truck or in your pocket? Even though my 48 Dodge truck has a vin plate on the door jam, the title has the number from the motor on it. I have also heard of frame numbers being used on the title. I have also heard of buying those blank vin plates off ebag and putting the seriel number off of the title that you just bought off of a guy at a swap meet.
Re: VIN plate help [Re: THE GLASS MAN] #1574200
02/05/14 11:53 PM
02/05/14 11:53 PM
Lon207 Offline OP
Lon207  Offline OP
Thanks folks.
The VIN plate is actually in my pocket!!! Took it off a 46 cab that I bought. The 47 complete truck I have-doesn't have a plate. Just trying to figure out which way to go. Title it to the plate? title it with numbers from the frame (with ebag plate to match)? Just trying to see what the serial numbers came back as. How can I look those up? Any suggestions?
Re: VIN plate help [Re: Lon207] #1574201
02/06/14 02:33 AM
02/06/14 02:33 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
If the 47 doesn't have a vin plate, why don't you ask the state to issue a new vin number for the truck? The state of Tennessee issued a new vin number for my 55 pick up. They also provided a vin plate with the new vin number.
Re: VIN plate help [Re: Dabee] #1574202
02/06/14 07:52 AM
02/06/14 07:52 AM
AZ
Mike P Offline
Mike P  Offline
AZ
I went thru this with a 37 Dodge PU.....no vin tag and truck titled by the engine number and the engine was long gone.
As I found out after buying a shop manual, the frame is also stamped with the vin. It took about 1/2 a day at DMV to get that all straightened out but I now a legit paper on it.
Now if a sharp LEO decides to check numbers on the truck, which do you think he's going to go by, the stamped numbers on the frame or a tag that's held on with 2 screws? You can do what you want, but personally I kind of like knowing before I put a bunch of money in a project that I actually own it with good paper.
Laws vary greatly from state to state but finding a frame number and talking to DMV is where I would start first.
Re: VIN plate help [Re: Mike P] #1574203
02/06/14 09:01 PM
02/06/14 09:01 PM
Lon207 Offline OP
Lon207  Offline OP
Thanks for the advice guys. I'm in Murfreesboro, TN so I may go with getting a new VIN and title issued.
Where is the VIN stamped on the frame? Where on the engine? The 47 is a complete truck at the moment.
thanks again.
Re: VIN plate help [Re: Lon207] #1574204
02/09/14 07:16 PM
02/09/14 07:16 PM
Lon207 Offline OP
Lon207  Offline OP
OK-I checked the frame in front of axle on left front. no numbers. I did check the engine-here's what is stamped on the engine pad
TII2*I04079* ( not sure if the I's are not actually 1's.)
What year does the engine appear to be from? thanks
Re: VIN plate help [Re: Lon207] #1574205
02/10/14 10:42 PM
02/10/14 10:42 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i would tread lightly with DMV and law enforcement questions and also be wary of asking for inspections----99% of LEO dont know what they are looking at---and the 1% that have had a little training are the experts that will be inspecting your vehicle and finding any little fault( because if they find fault it justifies their position) and they may refuse you and maybe even impound the vehicle...
Re: VIN plate help [Re: Dabee] #1574206
02/10/14 11:45 PM
02/10/14 11:45 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Lon 207 didn't you say you live in Tennessee? The county clerk told me Tennessee requires 17 characters in the vin for each new tidle issued. This is a federal government requirement. I have the original VIN plate for my 55, but the state issued a new 17 character VIN anyway. Why don't you give the country clerk a call and ask?
Re: VIN plate help [Re: Dabee] #1574207
02/10/14 11:55 PM
02/10/14 11:55 PM
Lon207 Offline OP
Lon207  Offline OP
dabeast2,
Thanks for the info. yes, I'm in Murfreesboro, TN. I just may call the county clerk to do that. I'm just trying to figure out the year the best way I can.
thanks
Re: VIN plate help [Re: Lon207] #1574208
02/11/14 01:42 PM
02/11/14 01:42 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Okay, good luck.
Re: VIN plate help [Re: Dabee] #1574209
02/12/14 11:39 AM
02/12/14 11:39 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
keep us posted on how you make out with this topic and good luck to you,,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: VIN plate help [Re: fstfish66] #1574210
02/12/14 12:29 PM
02/12/14 12:29 PM
SE VA
Hoyt Offline
Hoyt  Offline
SE VA
In VA, the state police handle things like this. I have found them very supportive of car enthusiasts. There is no need to try sketchy ways of getting VIN tags as long as you have documentation of purchase/ownership and contact them -before- you proceed. They have helped me remove and replace VIN tags for a restoration, use a vintage VIN tag that did not come with the car, get a completely new VIN tag, correct title errors (transposed VIN numbers), and so on.
They aren't after the average car guy, but are looking for criminal types who engage in VIN fraud. The key to success is working with them, not trying to slip something by them.
Re: VIN plate help [Re: Hoyt] #1574211
02/15/14 02:59 AM
02/15/14 02:59 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
its nice to hear there are places where good stuff happens to good people...
