Re: Wheel Bolt Pattern Cross Reference Database.
[Re: 4dr4x4]
#1573943
02/04/14 02:03 PM
02/04/14 02:03 PM
Guitar Jones
Great except it's crap, It lists 1/2 ton and 3/4 ton as the same or only the 94 and up 3/4 ton. No 1 tons or duallys and no older 8 lug trucks. How can you trust it?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 4dr4x4]
#1573945
02/04/14 03:17 PM
02/04/14 03:17 PM
Guitar Jones
I know that years ago, although the lug pattern was the same between a Ford and Mopar, the center register was not. You could swap one way but not the other. Most aftermarket wheels are large enough that the center register will fit, but then they become lug concentric instead of hub concentric.
[Re: 76dodgeboy]
#1573949
02/05/14 10:14 AM
02/05/14 10:14 AM
Guitar Jones
Not sure on the Ford trucks but the cars were 5 on 4.5 as the Mopars were. GM's were 5 on 4.75. When everyone started going FWD is when things got mixed up.
[Re: Guitar Jones]
#1573950
02/05/14 01:38 PM
02/05/14 01:38 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Depends What cars. Some of the Big 70s models had the 5x5"(aswell as Chevys Big cars) but was only a select few. Ford 30s and 40s were 5x5.5" also.
[Re: dogdays]
#1573951
02/05/14 01:40 PM
02/05/14 01:40 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
I don't think so, at least for more modern stuff. My '77Ford $500 truck was going to look so trick with a very cheap set of Dodge Ram 16" wheels, the rear fit OK but the fronts the centerbore of the Ram wheel is quite a bit smaller than the ford, I had to use spacers. Aftermarket wheels usually clear everything.
R.
Believe Jamie may have been refering to the 4.5" Bolt pattern. The 94 up Dodge wheels dont even fit pre 94s
[Re: hp383]
#1573953
02/05/14 07:11 PM
02/05/14 07:11 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
On a side note, from this little wheel finder, I now know I can use Viper wheels on my Dak. But I am thinking the Viper wheels were not 15x6 as listed in the app. I have a contact that races Vipers, and may be able to get a set of factory wheels to try on the truck. That would be neat.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1573954
02/05/14 08:28 PM
02/05/14 08:28 PM
Guitar Jones
Yes Viper wheels have the same bolt pattern as Dakota hubs were used on the Viper. But no they are not 15x6.
