Turn signal lever? #1573854
02/04/14 12:04 AM
02/04/14 12:04 AM
PA
RoadRunner73 Offline OP
PA
Are all the turn signal levers the same throughout the late 60-70s? And does anyone know where I can get a nice one for less than $45??
1973 Plymouth Road Runner
Re: Turn signal lever? [Re: RoadRunner73] #1573855
02/04/14 01:00 AM
02/04/14 01:00 AM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
What do you need one for? I can hook you up no prob I am sure.
Re: Turn signal lever? [Re: RoadRunner73] #1573856
02/04/14 03:55 AM
02/04/14 03:55 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I thought the E bodies had a little wild angle to em because of the spacer can?
Re: Turn signal lever? [Re: RoadRunner73] #1573857
02/04/14 10:09 AM
02/04/14 10:09 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
no,, they are all body style and year specific
Re: Turn signal lever? [Re: gtx6970] #1573858
02/04/14 10:16 AM
02/04/14 10:16 AM
PA
PA
I need one for my 73 RR - mine is all rusted.
Re: Turn signal lever? [Re: buildanother] #1573859
02/04/14 10:18 AM
02/04/14 10:18 AM
PA
PA
Looks that way going by this page they have the E Bodys seperate...
http://www.jimsautoparts.com/electric.htm
Re: Turn signal lever? [Re: RoadRunner73] #1573860
02/04/14 10:24 AM
02/04/14 10:24 AM
PA
PA
I guess this one seems to be right if I go by that other site... anyone disagree?
http://www.ebay.com/itm/321309908871?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: Turn signal lever? [Re: RoadRunner73] #1573861
02/04/14 12:37 PM
02/04/14 12:37 PM
Alberta, Canada
K
K
Alberta, Canada
I think it is the right one.
Re: Turn signal lever? [Re: RoadRunner73] #1573862
02/07/14 04:06 AM
02/07/14 04:06 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
If not too bad, rusty chrome plate on steel can sometimes be completely resurrected.
It seems as though the iron rust molecules migrate to the top surface of the chrome plating and can be removed back down to the bare chrome by polishing. Select a test area to concentrate on, and polish with a chrome polish as long as you can keep detecting any slow improvement. As much as two or three hours of hand polishing may be needed, well worth it to save an original part.
This is the way I saved my turn signal lever and floor shift lever.
I tried, but the chrome exhaust tips just didn't show any improvement.
Re: Turn signal lever? [Re: kentj340] #1573863
02/07/14 02:45 PM
02/07/14 02:45 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I agree. I took some never dull to mine and it took the rust right off. Only took 10 or so minutes.
Re: Turn signal lever? [Re: parksr5] #1573864
02/07/14 03:53 PM
02/07/14 03:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try a piece of wadded aluminum foil and water.Rub lightly and if it isnt deep it should shine.Rocky
Chrysler Firepower
Re: Turn signal lever? [Re: therocks] #1573865
02/07/14 08:55 PM
02/07/14 08:55 PM
PA
PA
Mine was pretty bad someone left it outside... Found one on eBay for a couple bucks
