Throwout bearing question #1573621
02/03/14 05:26 PM
02/03/14 05:26 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I was going through a box of old Mopar parts I have and came across a couple of throwout bearings. I am an automatic guy so I don't know much about 4-speed stuff. What I would like to know is are throwout bearings small and big block specific? If so, how can I tell the difference in order to figure out what I have?
Re: Throwout bearing question [Re: 1970RT] #1573622
02/03/14 05:56 PM
02/03/14 05:56 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Small and big block TO bearings are the same, but there are 2 types. One for a 23 spline and one for an 18 spline transmission.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Throwout bearing question [Re: 68LAR] #1573623
02/04/14 12:53 AM
02/04/14 12:53 AM
Cab_Burge Online work
Cab_Burge  Online Work
Not so on all Mopar applications, if it is a passenger car then that may apply If thier from a pickup, van or a larger turck maybe not I've seen some that are a lot different in the length of the mounting collars between the clucth fork and bearing mounts positions
Re: Throwout bearing question [Re: Cab_Burge] #1573624
02/04/14 01:20 AM
02/04/14 01:20 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Here is a picture of both bearings. They both have 1 5/16" holes in them. They are the same height but notice the difference in the shape on the bottoms ends.
Re: Throwout bearing question [Re: Cab_Burge] #1573625
02/04/14 04:04 AM
02/04/14 04:04 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Sorry, MY BAD. I thought we were talking about cars.
Re: Throwout bearing question [Re: 68LAR] #1573626
02/06/14 04:56 PM
02/06/14 04:56 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Is the difference in the shape of the two bearings in the picture I posted of any significance?
Re: Throwout bearing question [Re: 1970RT] #1573627
02/06/14 05:04 PM
02/06/14 05:04 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
No. The difference in the thickness of the bearing its self is due to the manufacturer. The mounting body looks identical. The difference between a 23 spline and an 18 spline is the inside diameter of the mounting body/bearing. The bearing you have pictured look like car bearings. Admittedly, I know very little about truck bearings. They could be the same or different. I you couldn't prove it either way by me.
Re: Throwout bearing question [Re: 68LAR] #1573628
02/06/14 05:38 PM
02/06/14 05:38 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Interesting....I would like to know the difference also....
Here is a supposed Hemi release bearing that doesn't look anything like the pictured ones.
http://www.ebay.com/itm/OEM-Mopar-HEMI-4...tr#ht_932wt_788
Re: Throwout bearing question [Re: KillerBee] #1573629
02/06/14 09:14 PM
02/06/14 09:14 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The Hemi T.O. bearing has a larger center hole.
