AAR -manual or electric washer reservior pump? #1573612
02/03/14 04:59 PM
02/03/14 04:59 PM
Minnesota
goat432 Offline OP
goat432  Offline OP
Minnesota
Did AAR's come with manual or electric washer reservoir pump? Either way possible? Something I guess I never paid close enough attention to & now I need to know. Thanks for any help in advance.
Re: AAR -manual or electric washer reservior pump? [Re: goat432] #1573613
02/03/14 05:25 PM
02/03/14 05:25 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Both
NS1AAR
Re: AAR -manual or electric washer reservior pump? [Re: goat432] #1573614
02/03/14 06:45 PM
02/03/14 06:45 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
If equipped with the optional rallye dash, they had an electric pump. The standard dash cars had a manual pump.
Re: AAR -manual or electric washer reservior pump? [Re: 318 Stroker] #1573615
02/03/14 07:42 PM
02/03/14 07:42 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
w/ 318Stroker
Yup, yup, that's what I've been told too.
Mo' Farts
Moderated by "tbagger".
Re: AAR -manual or electric washer reservior pump? [Re: Grizzly] #1573616
02/03/14 11:03 PM
02/03/14 11:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The variable motor which included the electric washer pump was also available as an option on cars with the standard cluster. The broadcast sheet code for it is J25.
Re: AAR -manual or electric washer reservior pump? [Re: Alaskan_TA] #1573617
02/03/14 11:40 PM
02/03/14 11:40 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Thanks Barry... I forgot about that option.
Re: AAR -manual or electric washer reservior pump? [Re: 318 Stroker] #1573618
02/03/14 11:49 PM
02/03/14 11:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have a database built for T/A broadcast sheet codes, I have only 16 known with J25 without A62 so far.
Hopefully, someday if time ever allows it I can build a similar database for AAR broadcast sheet codes.
Also, for anyone that may not have heard yet, the next AAR & T/A Reunion will be at the Chryslers at Carlisle show in 2015.
Re: AAR -manual or electric washer reservior pump? [Re: Alaskan_TA] #1573619
02/04/14 12:05 AM
02/04/14 12:05 AM
Minnesota
goat432 Offline OP
goat432  Offline OP
Minnesota
Once again, thanks to all.
Re: AAR -manual or electric washer reservior pump? [Re: Alaskan_TA] #1573620
02/04/14 04:27 PM
02/04/14 04:27 PM
middle of the country
aar1 Offline
aar1  Offline
I have an AAR that came with a standard dash and a 3 speed wiper motor and it does have the electric washer pump.
