Page 2 of 3 1 2 3
Re: High RPM Misfire -- SOLVED! [Re: NewMemberAgain] #15724
07/07/05 08:23 AM
07/07/05 08:23 AM
this world
drifter Offline
drifter  Offline
this world
JIM i may be way off here but i'll give it a go. I know on my msd stuff like 7al2 etc. it states Do Not use SOLID core spark plug wires!! I see in your pic the wires and don't they say SOLID on them? I am not sure if the digital msd can use them but it was worth a shot in saying my 2 cents
Re: High RPM Misfire -- SOLVED! [Re: drifter] #15725
07/07/05 08:26 AM
07/07/05 08:26 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Just out of curiosity, what comprises a "sheilded" wire? Is it a special insulation? I have extended pickup wires before, I thought it was regular fine multistrand wire? Great post, BTW.
Re: High RPM Misfire -- SOLVED! [Re: moper] #15726
07/07/05 11:48 AM
07/07/05 11:48 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
WOW Nice Job 440JIM
I have been lurking and waiting I dont think I would have ever figured that out. Nice Job sometimes its just little things that make the diff.
Re: High RPM Misfire -- SOLVED! [Re: 340RICK] #15727
07/07/05 12:08 PM
07/07/05 12:08 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Good work Jim. Electrical gremlins can be a real PITA.
2 kids and a dog
Re: High RPM Misfire -- SOLVED! [Re: NewMemberAgain] #15728
07/07/05 12:47 PM
07/07/05 12:47 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I thought that it was a no no to run solid core spark plug wires with an MSD ignition?
NewMemberAgain (BP),
Those are MSD Heli-core suppression wires. The label on the wires uses the word "solid suppression" but that is misleading. The wire is wound around a core to give noise suppression. They are approved for the MSD ignitions. From the instructions, "A good quality, helically wound wire and proper routing are required to get the best performance from your ignition, such as the MSD Heli-Core or ..."
jamesc,
I asked the MSD rep about the MSD noise capacitor for the power leads on the box. He said that was to stop the MSD from interfering with other equipment. Not my problem. But I agree with you it might be good insurance and can't hurt.
moper,
A shielded cable has an electrically conductive material covering the insulated wires inside. This material is grounded at one end of the cable. This shields the inner wires from electromagnetic fields outside the cable.
Re: High RPM Misfire -- SOLVED! [Re: 440Jim] #15729
07/07/05 12:59 PM
07/07/05 12:59 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
So how do pickup wires get classified that way? I have used plug wires (a while ago..I got them 'cause they looked cool..lol) that used a grounding strap like that, but pick-up dont. Or does the dist casing do it?
Re: High RPM Misfire -- SOLVED! [Re: moper] #15730
07/07/05 01:09 PM
07/07/05 01:09 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
You need a special cable. They are not that way from the factory. That was why I was picking up the electrical noise from the alternator.
Re: High RPM Misfire -- SOLVED! [Re: 440Jim] #15731
07/07/05 04:02 PM
07/07/05 04:02 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Ok, thanks Jim..didnt mean to sound "thick"..lol
Re: High RPM Misfire -- SOLVED! [Re: 440Jim] #15732
07/07/05 07:10 PM
07/07/05 07:10 PM
Central Missouri Fort Leonard...
mopar65 Online happy
mopar65  Online Happy
way to go jim. i like how you fix it and not just throw a bunch of parts at it. hopeing to fix it.allso i am not trying to tell you what to do and you are a lot smarter than me.but next time try taking the wires comeing from your distributor. and twist them around each other.that way they act like a home made shielded cable.like you said two wires running right beside each other act like a little antina.thats what i had to do to a wheel speed sensor on a car when i worked at GM. i hope i said that to wear you can understand it.but any way good gob on fixing your car.mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
'Solid Core Wires' [Re: 440Jim] #15733
07/07/05 10:29 PM
07/07/05 10:29 PM
St. Catharines, ON
N
NewMemberAgain Offline
super street
super street
N
St. Catharines, ON
Wow!
That is great news Jim. That means for me, that i do not have to buy another set of sp wires.
Those wires as mentioned are the sames one that I have, but never used because.
I am glad that i asked, maybe it might help my msd box...
Thanks again Jim for clarifying that.
BP
Re: 'Solid Core Wires' [Re: NewMemberAgain] #15734
07/07/05 10:54 PM
07/07/05 10:54 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Just to show I am not made of steel...
Revving the engine in the garage, in neutral to 6000 or 7000 rpm is a little un-nerving. But I did warm the engine before I did it, and that included both the water and the oil. Then I don't like "zinging" the RPM, but rather did a controlled steady increase in RPM. It started to sound a little like listening to NASCAR on TV as the engine passed 5000, 5500, 6000, 6500... After the first few times, it actually sounded nice. But a day later, thinking back, it was a little stressful! It was much worse when it would misfire at 5000 rpm, rather than the beautiful sound of the steady climb past 6000...
Re: High RPM Misfire -- SOLVED! [Re: 440Jim] #15735
07/09/05 09:45 PM
07/09/05 09:45 PM
Long Island, NY
B1Ken Offline
B1Ken  Offline
Long Island, NY
I'd like to drag this topic out of the archive because I'm having the same problem with my T-Bird. Last year, at the Keystone Natsionals, I noticed a misfire towards the end of the track (probably 7000-7600 rpm.). I suspected the RPM limiter might be the problem so I replaced the 8000 "chip" with an 8200 one and it seemed to fix it. This year it started to act up again, and I "fixed" the problem with a borrowed MSD box (7AL-2). I then put the original MSD box back in (was misfiring with a new box) and the problem came back. I reinstalled the borrowed box but this time it didn't help. I just bought a new pick up for the distributor (Old Chrysler Prestolite) which I hope will help. I also bought the newer type spark retard so that I can try the crank trigger again. I used to break starters with the old spark retard. This is really annoying me because I lost in the fifth round at the Div 1 race at Lebanon Valley by .002 seconds. I would have had a bye run into the final. I can't really test it without going to the track. I read your "fix" (sheilded leads) but was wondering if perhaps a weak magnet in the pick up might make the system more sensitive to noise. I also have a one wire GM alternator mounted close to the distributor, but ran this way for years without trouble. One other thing. The coil (MSD Pro Power) is mounted on the firewall. The car had a BB Chev. in it before I got it so the coil was close to the distributor. I checked the resistance of the plug wires and found that the MSD wires had about 100 ohms per foot. The coil wire was a Moroso wire which has about 1000 ohms per foot. That wire is about two feet long. I'm guessing I didn't have enough MSD wire for the coil wire so I used a wire from the Moroso set. I used to run Moroso wire all of the time and never had trouble. I did change the wire to a slightly shorter one at the track but it didn't help. Maybe I should mount the coil closer to the distributor.
Re: High RPM Misfire -- SOLVED! [Re: B1Ken] #15736
07/09/05 10:14 PM
07/09/05 10:14 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
B1Ken, are you running a Digital MSD (Digital 6,7)or are you running an Analog box (7AL2,3)?
LBSR
Re: High RPM Misfire -- SOLVED! [Re: B1Ken] #15737
07/10/05 10:49 AM
07/10/05 10:49 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Ken,
Do you have the shielded cable to the distributor?
I tried two different magnetic pickups in my distributor during the trouble shooting, and they acted the same. I guess if one is deteriorating and the signal is not as strong, the signal to noise ratio would get worse and might reach the MSD interference limit.
I was running for years also. It started with the addition of 15 amps more alternator load and I am thinking that more alternator output made more noise and reached the threshold. Also I noticed the Delco alternator would be better when cold, and after heat soaking and round robin, it got worse (interference).
After trying all those things and each time the car misfired, then doing this cable mod and having it work perfect, I felt so relieved. I am going to mod my spare distributor the same way. Maybe I should log off this computer and go to the shop and do it, now!
Re: High RPM Misfire -- SOLVED! [Re: 440Jim] #15738
07/10/05 11:06 AM
07/10/05 11:06 AM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
Where can you get the shielded cable? Is this something MSD sells.
Re: High RPM Misfire -- SOLVED! [Re: maxi426] #15739
07/10/05 02:03 PM
07/10/05 02:03 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Summit part # MSD-8862 $18.88, got one last week ( to replace the one that I BARB- B - Q'd )
Re: High RPM Misfire -- SOLVED! [Re: Bill_LBSR] #15740
07/11/05 04:27 PM
07/11/05 04:27 PM
Long Island, NY
B1Ken Offline
B1Ken  Offline
Long Island, NY
Bill: I'm using a 7AL2 (analog)
Jim: I was talking to my son last night about the problem and I remembered that I had the alternator repaired midway through the season last year. The repair definitely increased the output of the alternator. The signal cable from the distributor runs within 3" of the alternator and is not shielded. I think I'll try your recommendation.
Actually, though, I'd like to hook up the crank trigger again. My Chevy buddy, who used to break starters like me, said that the new style MSD spark retard, works great for him. I just ordered one. One way or another, I have to get this fixed. I have a points race at Delmar this week and the Sports Nationals at Columbus at the end of the month. It ain't easy dialing this thing with it running like crap on the top end.
Re: High RPM Misfire -- SOLVED! [Re: B1Ken] #15741
07/12/05 12:37 AM
07/12/05 12:37 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
All I can say for sure, is it solved my problem. I modified my spare distributor now too. The new Power master 100 amp was worse than the old 63 amp alternator at the same amp draw.
Re: High RPM Misfire -- SOLVED! [Re: 440Jim] #15742
07/12/05 07:44 AM
07/12/05 07:44 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Jim after reading this I went out and put a ground strap on the altinator. I wasen't having a problum but I guess it cant hurt. I use the pickup cable with the shield, but have a pigtail coming out of the MSD distributor old styel about 8" so maybe I will shorten that up too.
Thanks for keeping us up to dated.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: High RPM Misfire -- SOLVED! [Re: wildcargo] #15743
07/12/05 10:29 AM
07/12/05 10:29 AM
Long Island, NY
B1Ken Offline
B1Ken  Offline
Long Island, NY
I can't see what this would accomplish, since the alternator is bolted directly to the engine. If the alternator wasn't grounded already, it wouldn't put out any current.
Page 2 of 3 1 2 3
