78 4X4 diff. problem #1573397
02/02/14 11:14 PM
02/02/14 11:14 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
My 78 4X4 diff. is worn out at the output to the wheels. Is there a repair kit maybe have to have the case re-machined?
Re: 78 4X4 diff. problem [Re: 696pack] #1573398
02/02/14 11:50 PM
02/02/14 11:50 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Need a better explanation? Front or rear?
Re: 78 4X4 diff. problem [Re: NITROUSN] #1573399
02/03/14 12:14 AM
02/03/14 12:14 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Front
Re: 78 4X4 diff. problem [Re: 696pack] #1573400
02/03/14 01:18 AM
02/03/14 01:18 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Front
Are you talking about the housings that the wheel bearings go into or the actual ring and pinion center housing?
Re: 78 4X4 diff. problem [Re: NITROUSN] #1573401
02/03/14 03:03 AM
02/03/14 03:03 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Front
Not the wheel bearing the actual diff.
Re: 78 4X4 diff. problem [Re: 696pack] #1573402
02/03/14 10:33 AM
02/03/14 10:33 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I assume the races fit to loose in the housing? If so I replace the housing. If its just loose bearings they can be replaced.
Re: 78 4X4 diff. problem [Re: NITROUSN] #1573403
02/03/14 05:06 PM
02/03/14 05:06 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
My mechanic says it is the housing and asked if anyone knew of a repair kit or if we were going to have to get a different housing. I thought that maybe there was an oversize kit available for this problem.
Is there a new housing available somewhere?
Re: 78 4X4 diff. problem [Re: 696pack] #1573404
02/03/14 07:05 PM
02/03/14 07:05 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I have a couple used but Im in Iowa. I can sell complete ire strip it of all moving components. if interested you can call me 402-515-3036 Im swapping in D60s
Re: 78 4X4 diff. problem [Re: 76dodgeboy] #1573405
02/03/14 07:08 PM
02/03/14 07:08 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
New would be a Custom unit and rather pricey.
Re: 78 4X4 diff. problem [Re: 696pack] #1573406
02/09/14 04:21 AM
02/09/14 04:21 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Do you need a Dana 60F or a Dana 44? The HOUSINGS (respectively) are pretty much interchangeable from 1973-1993, so they should be fairly easy to find. Heck, if you shop around, you can probably find one that already has the proper gears in it. Dana 44's are very common, as where a 60F will be harder to find, and more $$$$
Re: 78 4X4 diff. problem [Re: 440trk] #1573407
02/09/14 08:48 AM
02/09/14 08:48 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I would use a differential out of a 75-93 model. On the earlier divorced transfer case trucks, the pinion angle points farther down, increasing the drive line angle. Just find a unit that has the same gears, and swap it. If you find a locking hub model, you can swap your stuff from the ball joints out. I wouldn't recommend keeping the full time junk, but the part time has a different wheel bolt pattern A 3/4 ton dana 44 will work just as well, but you will have to swap everything from the ball joints out, and 4.10 gears are most common. The full time stuff commonly has 3.55. Good luck.
Re: 78 4X4 diff. problem [Re: NITROUSN] #1573408
02/09/14 01:25 PM
02/09/14 01:25 PM
SC
BPDodge Offline
BPDodge  Offline
SC
I had a 77 Power Wagon. I worked at 2 Dodge Dealers back then. The problem was due to lack of grease the steering knuckles would wear out and just replacing the bearing and retainer kit would not always solve the problem. The big hole in the knuckle would wear just enough that the wheel would still wobble if axle was supported by a floor jack. Solution is to find a knuckle that is not worn out so bad.
