P0118 Code on my 98 ram 5.9 V8 *DELETED* #1572595
02/01/14 11:08 PM
02/01/14 11:08 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
Post deleted by 98RAM1500
Re: P0118 Code on my 98 ram 5.9 V8 [Re: 98RAM1500] #1572596
02/01/14 11:24 PM
02/01/14 11:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Your guessing game will cost you. Describe hard starting? Long crank time or slow turning over?
Re: P0118 Code on my 98 ram 5.9 V8 [Re: NITROUSN] #1572597
02/02/14 12:31 PM
02/02/14 12:31 PM
Crockett ,TX
9
Crockett ,TX
it was the water temp sending unit. The gauge would work then it wouldn't so replaced the temp unit & been working good since yesterday, idles good like its supposed to.
Re: P0118 Code on my 98 ram 5.9 V8 *DELETED* [Re: 98RAM1500] #1572598
02/02/14 01:34 PM
02/02/14 01:34 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Earning every penny of that moderator paycheck.
DBAP
Re: P0118 Code on my 98 ram 5.9 V8 *DELETED* [Re: not_a_charger] #1572599
02/02/14 01:50 PM
02/02/14 01:50 PM
Crockett ,TX
9
Crockett ,TX
I was trying to edit it but I accidentally click delete its one of those mornings
Re: P0118 Code on my 98 ram 5.9 V8 [Re: 98RAM1500] #1572600
02/02/14 02:34 PM
02/02/14 02:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The sending unit for the gauge does nothing for the efi. The efi takes its own coolant sensor which is for the efi only.
Re: P0118 Code on my 98 ram 5.9 V8 [Re: NITROUSN] #1572601
02/02/14 03:21 PM
02/02/14 03:21 PM
Crockett ,TX
9
Crockett ,TX
I ment to say the coolant temp sensor earlier (not water temp got my words mixed) & the truck has done went over 40-50 miles since & no problems idles fine, starts fine, no check engine light so idk
