Re: LA vs Magnum Eddy heads?
[Re: mopartruckguy]
#1572590
02/01/14 11:27 PM
02/01/14 11:27 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Not always as there are many articles on how to put a magnum head on an LA engine.
but..putting a LA head on a magnum engine is the problem...
so if you have a LA engine you can buy either head...but why by the magnum head and use stud mounted rockers..and have to get a different intake..so I would buy the LA head since I got boxesrockers..and 20 intake manifolds..
If you have a magnum engine..try putting the LA version on it...how you going to get oil into the shafts..??...
yeah...some early magnum blocks might of/ could of came with oil hole in the head...but is the cam drilled to feed the oil galleries...or you can take it to the machine shop and have the oil passaged drilled...good luck on what that will cost...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1572591
02/02/14 12:51 AM
02/02/14 12:51 AM
RapidRobert
You can drill horizontally in at the rear of the LA head(s) into the bolt boss then down at an angle from the rear pedestal bolt threads to reach that horizontle passage. Then T off of the oil port at the top rear of the block to feed em & a holley jet in the passage to meter the flow.
[Re: RapidRobert]
#1572594
02/02/14 12:08 PM
02/02/14 12:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
open versus closed chambers?
Putting LA heads on a Magnum is not more difficult than the reverse. Different things need doing, but in terms of labor and cost, not really much different.
