Page 1 of 3 1 2 3
MSD troubleshooting #1572543
02/01/14 10:49 PM
02/01/14 10:49 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang....
Got my MSD 6AL for the ole' Daytona. I've wired it up and everything seems to be fine according to the schematics from MSD. The problem the distributor isn't triggering a signal. I have for now, a single point distributor that works perfectly fine and the motor idles and rev's up to rpm without any problems. I am using it as a trigger for now. Will eventually get a Prestolite converted to a Chrylser Electronic system and use that. But, for now, I wanted to get it in the car and running.
Based on the troubleshooting procedures with the kit, I have done:
1. Ignition on., ground the wire wire from the MSD box utilized for point triggering and snap, nice spark...... Sweet...
2. but when I hook it up to the distributor's lead, nothing....... Soo, I'm confused now. The distributor in it's "Natural state" with everything hooked back OEM works just fine...... puzzled.....
PS. I am using the recommended MSD coil when I'm trying to fire up the car with the MSD unit.
For now, I am not utilizing the gray tach wire...... I just wanted to get the MSD system up and going.....
Cheers,
Troy
Troy
Houston Mopar Connection Club
Re: MSD troubleshooting [Re: hemi68charger] #1572544
02/01/14 11:06 PM
02/01/14 11:06 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Just to verify you have the white wire to the point pickup and the red wire to switched 12V source
If so verify you have 12V at the switched source while cranking and when the key is released (or just jump it to the Battery just to test)
I had a issue where a connector backed out of the connector body just enough where it would show 12v on a meter but wouldn't flow any current ( apparent power)
Took awhile to figure out
Re: MSD troubleshooting [Re: SSAAHemiFan] #1572545
02/02/14 12:44 AM
02/02/14 12:44 AM
montreal, quebec,canada
7e5dartsport Offline
only logic i can think of is that the distributor body is not grounded. take a test light, hook it up to the battery POSITIVE terminal and touch the distributor body with the other end of the test light, it should light up. repeat that WHILE CRANCKING. if it does light up, unhook the distributor single wire from the msd box and with the test light still on battery positive, touch the dist. wire while crancking, it should alternatively come on and off, confirming its operating condition.
also make sure you are using the msd WHITE wire when using points.
good luck.
fully legal sounds the same as full illegal...
Re: MSD troubleshooting [Re: 7e5dartsport] #1572546
02/02/14 01:15 AM
02/02/14 01:15 AM
Houston, Tx
Houston, Tx
...also make sure you are using the msd WHITE wire when using points.
good luck.
Yeap, for sure the white wire is being used...... When I ground the MSD white wire with the ignition in the run position ( 12v source for the unit ), it archs really nice..
I know it is something rather simple......... Shutting down for now and will tinker some more tomorrow before the SuperBowl.....
Troy
Re: MSD troubleshooting [Re: 7e5dartsport] #1572547
02/02/14 07:29 PM
02/02/14 07:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
good luck.
hmmm, i don't think its a case of the dizzy not grounding cause he says it will run when not using the MSD. it may be an issue with the points gap. are you using the correct ballast resistor for that coil and points dizzy? that could be the problem. pop in the stock coil and see what happens edit - are you using a dual point dizzy?
Re: MSD troubleshooting [Re: mikemee1331] #1572548
02/02/14 08:24 PM
02/02/14 08:24 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Are you sure that the points are opening?
Re: MSD troubleshooting [Re: GTX MATT] #1572549
02/02/14 08:41 PM
02/02/14 08:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
says it runs when he takes the MSD out. also, sorry i didn't see where you said single point dizzy . i think you have a resistance issue.
Re: MSD troubleshooting [Re: mikemee1331] #1572550
02/03/14 12:15 AM
02/03/14 12:15 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
good luck.
MSD does not use a ballast resistor even when using stock coil. If you are using it, it needs to be bypassed.
Kevin
Re: MSD troubleshooting [Re: Twostick] #1572551
02/03/14 01:03 PM
02/03/14 01:03 PM
Houston, Tx
Houston, Tx
good luck.
Kevin
Nope, when I have the MSD circuit hooked up, I don't have the ballast in the circuit. I am using the 12v feed to the ballast as the 12v feed to the red 12v feed wire ( small guage red wire )... I am using the MSD coil I got with my purchase per their recommendation. Then, I put everything back OEM and the car runs great; idles fine and throttle response is good. The distributor is a freshly remanufactured unit, so the points and such are brand new.
Thanks to all..... I'll call MSD later on today......
Troy
Re: MSD troubleshooting [Re: hemi68charger] #1572552
02/03/14 02:11 PM
02/03/14 02:11 PM
Houston, Tx
Houston, Tx
Well,
Just got off the phone with MSD tech support. As some of you have eluded to, the condensor is supposed to be disconnected. Wish the instructions would have mentioned that. It isn't very intuitive to remove it if you have never done it before. Suggested to him to add it to the instructions... Unless I missed it somewhere, I don't recall reading anything to that...
So, when I get home, quess what I'm doing?
Thanks again to all that replied............ I'll yell back my results for future reference.
Troy
Re: MSD troubleshooting [Re: hemi68charger] #1572553
02/03/14 02:40 PM
02/03/14 02:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Well,
Grrrr... i had totally forgotten about that little [Edited by Moparts - Family Friendly Site - Keep it clean], it's been that long! i should have known about the ballast cause it's bypassed when starting.
Re: MSD troubleshooting [Re: mikemee1331] #1572554
02/03/14 10:35 PM
02/03/14 10:35 PM
Houston, Tx
Houston, Tx
Well no-go...
I took the condenser out...... It's freakin' crazy. I put a test light with the ground on the distributor lead and put the point on the positive post and crank, the test light flashes on and off as it should. I put the white wire on the the distributor lead and I get arching from the coil wire to metal.. I do notice the first rotation or two, the arch isn't there then it comes on. I put the cap back on, take coil wire back on and take out plug 1 and hook up the spark plug wire and crank.... I get spark at the plug.. !!!! Grrrrrrrrrrrrrr,
but, when I put everything back, nada.. I moved the distributor advance ( thinking the timing is not the same with the MSD ), nothing.... Maybe I just need to go to an Chrysler Electronic distributor... Lordy...... This shouldn't be so complicated !!!
Troy
Re: MSD troubleshooting [Re: hemi68charger] #1572555
02/04/14 12:13 PM
02/04/14 12:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Well no-go...
this make no sense?? all the points are doing is switching on and off like a light switch. dwell is not a factor with MSD so if it was correct it should still be along with timing. what is the condition of the points? with a MSD the amount of voltage to the 'switch' is greatly reduced. if there is a film built up on them this could cause a problem as well as pitting and corrosion. these are just some thoughts. this is an original style dizzy with just 1 wire that would have been connected to the coil negative side? another thought is to double check the setting on the MSD box. make sure it is set for 8 cylinder. i know they are supposed to be but who knows?
Re: MSD troubleshooting [Re: mikemee1331] #1572556
02/04/14 01:41 PM
02/04/14 01:41 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Troy, do you have the white wire and the wire from the points connected directly, or do you have them both connected to the negative post on the coil? They should be connected directly and not on the coil. The same goes for the smaller gauge power wire for the MSD box, it should not be connected at the coil with the original coil power supply, they should be spliced directly.
Re: MSD troubleshooting [Re: GTX MATT] #1572557
02/04/14 03:12 PM
02/04/14 03:12 PM
Houston, Tx
Houston, Tx
No..
1. I have the white wire connected directly with the ditributor lead via an alligator clip and the small 12v iginition red feed for the MSD clipped to the 12v input to the ballast resistor ( the ballast resistor is not hooked up, I'm just using the plug as the 12v feed. I have it wire exactly like the MSD instructions state, just not permanently....... I also took out the condenser paying particular attention in not messing up the points gap.
Troy
Re: MSD troubleshooting [Re: hemi68charger] #1572558
02/04/14 03:55 PM
02/04/14 03:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The violet wire for magnetic pickup use isn't accidentally grounding out anywhere, is it?
Re: MSD troubleshooting [Re: GTX MATT] #1572559
02/04/14 04:10 PM
02/04/14 04:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
good thought! another thing to try is hooking the white wire up to the dizzy wire and tapping first the wire to the points (looking for spark)and then shorting the points and look for spark. you did say when you tap the white to ground you got spark right?
Re: MSD troubleshooting [Re: mikemee1331] #1572560
02/04/14 04:46 PM
02/04/14 04:46 PM
Houston, Tx
Houston, Tx
That's a big 10-4
Troy
Re: MSD troubleshooting [Re: hemi68charger] #1572561
02/04/14 04:56 PM
02/04/14 04:56 PM
an8sec70cuda Offline
A friend of mine can't login for some reason and asked me to post this for you...
The problem may be you have the hot ignition wire for the msd hooked up to the hot wire on the ballast resistor. On the cars running points the hot wire goes dead when you turn the key to start and the second wire on the ballast resistor becomes hot 12 volts bypassing the resister to points for starting and the other wire goes dead. When you let go of the key the second wire (brown on mine) goes dead and the (blue on mine ) goes back to hot. The brown and coil wire are crimped together on the dead side of the resister.
I just made a jumper across my resister so it doesn't matter which wire is hot.
This was only on points cars and the other wire gets it power right off the starter.
Maybe you can pass this along. He's been trying for several days.
Thanks, Mike
CHIP
'06 GMC 2500HD LBZ Duramax
Re: MSD troubleshooting [Re: an8sec70cuda] #1572562
02/04/14 05:07 PM
02/04/14 05:07 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks, Mike
i think (mistake i know) that he has a 2 wire ballast not the 4 wire and has the MSD getting power directly from the wire.
Page 1 of 3 1 2 3
