1971 Cuda "By Plymouth" emblem? #1572050
02/01/14 09:40 AM
02/01/14 09:40 AM
Sweden
kape1 Offline OP
kape1  Offline OP
Sweden
Is the black emblem correct for my 71 Cuda? Or is it the other one?
Karl
Re: 1971 Cuda "By Plymouth" emblem? [Re: kape1] #1572051
02/01/14 09:46 AM
02/01/14 09:46 AM
Sweden
kape1 Offline OP
kape1  Offline OP
Sweden
Re: 1971 Cuda "By Plymouth" emblem? [Re: kape1] #1572052
02/01/14 11:29 AM
02/01/14 11:29 AM
california
Mr D21 Offline
Mr D21  Offline
california
black is correct for ebody, the grey is for b-bodies
Re: 1971 Cuda "By Plymouth" emblem? [Re: Mr D21] #1572053
02/01/14 11:42 AM
02/01/14 11:42 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
No,black is for Cuda and grey is for Barracuda.Usully the black emblems get dull after some years..
Re: 1971 Cuda "By Plymouth" emblem? [Re: 71redcuda] #1572054
02/01/14 01:46 PM
02/01/14 01:46 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i always thought only the cuda's got a by plymouth name plates. the barracudas didn't get one.
the silver by plymouth was on early 80's volares.
perception is 90% of reality
Re: 1971 Cuda "By Plymouth" emblem? [Re: kape1] #1572055
02/01/14 02:22 PM
02/01/14 02:22 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You want the black one
Re: 1971 Cuda "By Plymouth" emblem? [Re: ScottSmith_Harms] #1572056
02/01/14 04:14 PM
02/01/14 04:14 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Agree, black will be correct ... Are those the repro ones, any indications on rear side?
Originals sometimes turned a dark chocolate brown over period of time from the elements.
Grey was B-body, like on the doors of 69 Roadrunner
Re: 1971 Cuda "By Plymouth" emblem? [Re: mccannix] #1572057
02/01/14 04:22 PM
02/01/14 04:22 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Re: 1971 Cuda "By Plymouth" emblem? [Re: 71redcuda] #1572058
02/01/14 04:26 PM
02/01/14 04:26 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Grey was B-body, like on the doors of 69 Roadrunner...and on Barracudas, 70 and 71 only...correct?
Re: 1971 Cuda "By Plymouth" emblem? [Re: mccannix] #1572059
02/01/14 04:44 PM
02/01/14 04:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These were made using a laminate process, basically an embossed foil with the "by Plymouth" raised up, the surrounding area colored in blacked (for Cuda versions) then a clear protective film was applied over the top. This laminate piece was glued into the chromed pot metal emblem. Over the years several Mopar name plates used this exact same pot metal emblem casting with various laminate inserts for the various applications. The only reproductions I've seen were poorly made and not manufactured in the same way and therefore not correct in the details. NOS versions are out there but usually several hundred dollars when found.
Re: 1971 Cuda "By Plymouth" emblem? [Re: ScottSmith_Harms] #1572060
02/02/14 06:19 AM
02/02/14 06:19 AM
Sweden
kape1 Offline OP
kape1  Offline OP
Sweden
Thanks! Good info as Always.
Karl
