Balancer #157194
11/26/08 11:42 AM
11/26/08 11:42 AM
Va Usa
beecrazy Offline OP
beecrazy  Offline OP
Va Usa
I looking at buying a new balancer for my new motor I would like your recomendation and why you like it.
Mainly a street car. Motor is a 505 based upon 440. Roller cam and ported aluminum heads. 69 Bee with 4 speed. Should be 650 to 700 HP
I was thinking of buying ATI but not sure pulley problems are worth it ??
I want good quality!
Kevin
Re: Balancer [Re: beecrazy] #157195
11/26/08 01:39 PM
11/26/08 01:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
ATI w/ stock pulleys here - no problem.
Re: Balancer [Re: BSB67] #157196
11/26/08 01:55 PM
11/26/08 01:55 PM
Va Usa
beecrazy Offline OP
beecrazy  Offline OP
Va Usa
So BSB67 do you know the model number of the ATI damper you have. Any spacer required ?
Kevin
Re: Balancer [Re: beecrazy] #157197
11/26/08 02:04 PM
11/26/08 02:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
ATI #917470E and a 0.060" water pump spacer from Mancini.
Re: Balancer [Re: BSB67] #157198
11/26/08 03:26 PM
11/26/08 03:26 PM
Va Usa
beecrazy Offline OP
beecrazy  Offline OP
Va Usa
So do you have to-do anything with alternator ?
Re: Balancer [Re: beecrazy] #157199
11/26/08 03:53 PM
11/26/08 03:53 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Will it work with this set up
http://www.440source.com/altparts.htm
Re: Balancer [Re: beecrazy] #157200
11/26/08 04:16 PM
11/26/08 04:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It is spaced outward the thickness of a washer.
