Re: Drag Week 62 Valiant's Small Block is finally ready!
[Re: MoparBilly]
#1571923
02/03/14 02:32 AM
02/03/14 02:32 AM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
Billy, should I post the graph up?
Geez Brian, wish I would've read that before I typed all that out!
Well at least your excited about this!!
[Re: tsanchez]
#1571929
02/05/14 01:15 AM
02/05/14 01:15 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Mr P. Body, The car should come in around 3150 with me and the aluminum headed engine on board. I'm hoping for 10.40-10.60, and then I'll work from there...
John, I have no idea what the heads flowed on Brian's bench, He just told me it wasn't as good as Bryce's numbers.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1571930
02/05/14 02:59 AM
02/05/14 02:59 AM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
615 ponies at 3150 race weight it should do teens or 20's in decent air right off the trailer. You got a fun lookin piece there bud
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: ksj]
#1571933
06/15/14 03:31 PM
06/15/14 03:31 PM
MoparBilly
Phoenix, AZ
Just when I thought I was out... They pull me back in!
The engine for the Valiant is sitting in Darryl's shop...I hope. I haven't been over there in a couple of weeks, and he was threatening to drop it into his Dart.
[Re: MoparBilly]
#1571935
06/15/14 05:34 PM
06/15/14 05:34 PM
But, it was up to Brian, and since he knew this thing would see serious street miles, had no oil at the lifter galley, and tied to the already purchased beehive springs, he decided to go conservative on the ramps. [bold]His choice was a comp flat tappet, 269/275 @.050, and 600/601 lift on a 111 Lobe separation.
The other parts Brian was left to procure were a new oil pump and shaft, billet roller timing chain set, .045 Cometics along with all the other gaskets, Manton 11/32 pushrods, SFI Balancer, and a SuperVictor intake. He re-used my Crane gold 1.5 rockers.[/bold]
So....it was over $4k for the above parts, balancing and assembly ?? Sounds like you have $10k+ in a 600 hp engine ??
[Re: MoparBilly]
#1571936
06/15/14 08:27 PM
06/15/14 08:27 PM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
Well my W2 motor is out of the car waiting for its new owner to pick it up. But you do have some time Billy before your motor goes in the Dart need to upgrade the 904 and change the front suspension to coil over. Car should be ready for testing as soon as the warm weather breaks. By the way you do have enough parts to set up a NOS system so I can run with those 8.5 outlaw guys don't you Billy?
[Re: Darryls-Demon]
#1571937
06/15/14 08:46 PM
06/15/14 08:46 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
Billy is the NOS man! You bet he's got enough laying around!
Brian Hafliger
[Re: ]
#1571938
06/15/14 11:26 PM
06/15/14 11:26 PM
MoparBilly
Phoenix, AZ
6 pak runner, I stopped at 9800$, just to keep my sanity. For a pump gas, 615hp small block, with street reliability that fits within the paramaters I established before the build, ie solid cam, stock header and rocker layout, etc. I could have built an 800hp BB race motor for the same money, but that would not have accomplished what I needed out of this combo.
[Re: J_BODY]
#1571941
06/16/14 05:14 AM
06/16/14 05:14 AM
MoparBilly
Phoenix, AZ
800hp big block for $9800.... I guess if you fell into parts here and there it could be done. Thought this thing was done, locked and loaded and ready to make the road trip to do battle! Hanging around Darryl should have rubbed off on ya by now!
Exactly J-body, It's much easier to "fall into parts here and there" when you and 4 family members have been running BB's for 30 years! It really should be "done, locked and loaded", if the Valiant ever gets to the front burner again, but it seems owning 5 mopars, can spread your focus, dollars, and time a little thin! Since I've made the return trip from Brian's shop with the engine, it's been an interesting year indeed...
[Re: MoparBilly]
#1571942
06/17/14 02:08 AM
06/17/14 02:08 AM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
Wow, how did I miss this thread? Haven't been around much but man good info here for sure! I'd like to see what the actual numbers the Airwolfs flowed on Brian's bench, comparing the point to point with the advertised numbers. What I'm more interested in seeing is the port CSA and CCs vs advertised, I think that has more to do with the top end power and relatively high peak torque RPM we see out of these. Like I said 300cfm is really like 100cfm over 20 or so seconds, because that's all the time an intake valve is open. I've always been one for full disclosure, some old timers may remember I offered up my Chapman stage VIs for flow testing years and years ago, I think 615 is very impressive especially when you compare it t Bryce's 633 horse motor with the same heads and basic shortblock, but with a higher lift solid roller cam. With the Rocky I just changed my cam in the 414 to a .665/.640 lift from .585/.570 and I'm anxious to get out there again, from looking at the charts I should be upping my shift points to around 7200 vs the conservative 6800 I've had my chip set to, no more power up there but it might help the shift recovery with my tight converter. (Until i put up the coin for a 'proper' 8", lol) I want to thank all you guys ( both publicly and PM privately) for sharing the info on the site. I've always been a stick racer so you auto guys have been school in me good! Billy the Valliant is Awesome! Can't wait to get the 440 W2 66 wagon done and running as well.
