Headman Headers in a A BODY 383 #157184
11/26/08 11:33 AM
11/26/08 11:33 AM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
i am told from BBD that Headmen B-body headers will work in a A-body with a little massaging,,Anyone done this.... My car is a 72 Dart Manual Steering
Re: Headman Headers in a A BODY 383 [Re: 340dart4spd ] #157185
11/26/08 03:43 PM
11/26/08 03:43 PM
With those hedman 1&3/4 ones on a 383/400 the pass side fits with a minute amt of grinding down at the collector but the drivers side needs major mods,you need some 1&3/4 mandrel bends & do some cutting/fitting/welding but it still ends being a reasonable priced/good fitting deal even with the fabrication involved.
Re: Headman Headers in a A BODY 383 [Re: 340dart4spd ] #157186
11/26/08 05:20 PM
11/26/08 05:20 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Way back in the 80s I used a set of Hedman headers in my 383 Dart, they were for a 69 roadrunner 383. fit great, no power steering six cylinder starter.
Re: Headman Headers in a A BODY 383 [Re: boydsdodge] #157187
11/26/08 05:22 PM
11/26/08 05:22 PM
3
Parts Problem
Parts Problem
3
from what I read... that is right!!!
Re: Headman Headers in a A BODY 383 [Re: 340dart4spd ] #157188
11/26/08 05:56 PM
11/26/08 05:56 PM
boydsdodge Offline
boydsdodge  Offline
But you could order a set of TTIs now adays.
Re: Headman Headers in a A BODY 383 [Re: boydsdodge] #157189
11/26/08 06:08 PM
11/26/08 06:08 PM
3
Parts Problem
Parts Problem
3
yes I know that.....just looking to go cheap route!!!
Re: Headman Headers in a A BODY 383 [Re: 340dart4spd ] #157190
11/26/08 08:07 PM
11/26/08 08:07 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
bigblockdart.com has a section on this in the tech archive.
My 74 duster 383 uses hedman 75150 accepts p/s.
Re: Headman Headers in a A BODY 383 [Re: boydsdodge] #157191
11/26/08 08:38 PM
11/26/08 08:38 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
The TTI's for the big block A body are only 1 3/4" diameter & came w/ huge dents for clearance.
Expensive w/ ceramic & thermal barrier coatings & I have the up for sale. May post them on ebay next week. Built a 451 stroker for my 383 4 spd formula S, so going to larger B body headers.
www.bigblockdart has an article in the tech archives about B body headers in a 383 A body.
Re: Headman Headers in a A BODY 383 [Re: Triggerfish] #157192
11/26/08 08:46 PM
11/26/08 08:46 PM
3
Parts Problem
Parts Problem
3
BBD is where I got my info
Re: Headman Headers in a A BODY 383 [Re: 340dart4spd ] #157193
11/26/08 11:02 PM
11/26/08 11:02 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Guess you posted while I was typing my post. I also have a set of older Headman 1 7/8" from my 69 Charger's 440, so may weld up the leaks & use them. The BBD article has some great pics of where to ding the tubes.
