Re: Headman Headers in a A BODY 383
[Re: 340dart4spd ]
#157185
11/26/08 03:43 PM
11/26/08 03:43 PM
RapidRobert
With those hedman 1&3/4 ones on a 383/400 the pass side fits with a minute amt of grinding down at the collector but the drivers side needs major mods,you need some 1&3/4 mandrel bends & do some cutting/fitting/welding but it still ends being a reasonable priced/good fitting deal even with the fabrication involved.
[Re: boydsdodge]
#157187
11/26/08 05:22 PM
11/26/08 05:22 PM
340dart4spd
Parts Problem
Parts Problem
Way back in the 80s I used a set of Hedman headers in my 383 Dart, they were for a 69 roadrunner 383. fit great, no power steering six cylinder starter.
from what I read... that is right!!!
[Re: Triggerfish]
#157192
11/26/08 08:46 PM
11/26/08 08:46 PM
340dart4spd
Parts Problem
Parts Problem
The TTI's for the big block A body are only 1 3/4" diameter & came w/ huge dents for clearance. Expensive w/ ceramic & thermal barrier coatings & I have the up for sale. May post them on ebay next week. Built a 451 stroker for my 383 4 spd formula S, so going to larger B body headers. www.bigblockdart has an article in the tech archives about B body headers in a 383 A body.
BBD is where I got my info
