Dakota and Magnum questions for rodders. #1571792
01/31/14 10:57 PM
01/31/14 10:57 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
1) Are the Dakota and Durango frames similar as far as being a donor for a '40s-'50s truck?
2) Do all Magnums share the same mounting position? Basically, if my donor had a 3.9 Magnum can I physically put a 5.2/5.9/4.7 in its place?
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Dakota and Magnum questions for rodders. [Re: Cheeto] #1571793
02/01/14 11:43 AM
02/01/14 11:43 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
No not all the frames are the same, the best ones for this swap are the 87-96 Dakotas. The 87-96 are narrower and take the five lug axels and rotors.
If you have a good frame I would just mustang II it. My frame was hacked beyond repair or I would of mustang II it.
Re: Dakota and Magnum questions for rodders. [Re: moparpollack] #1571794
02/01/14 03:44 PM
02/01/14 03:44 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
2wd and 4wd are different it is coil 2w vs torsion bar 4w-----early 2W frames are better because you can use the 5 on 4.5 hubs and you can buy 2 inch lowering spindles and if you need it lower you can also get 2 inch lowering springs....bob
Re: Dakota and Magnum questions for rodders. [Re: savoy64] #1571795
02/05/14 01:55 AM
02/05/14 01:55 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
I found some really good info on Allpar regarding the differences too. I looked at a Durango donor yesterday at the auction. The frame bows out right at the point where you'd want to shorten it. Bummer because Durangos are cheaper than Dakotas around here.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Dakota and Magnum questions for rodders. [Re: Cheeto] #1571796
02/05/14 02:14 AM
02/05/14 02:14 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe all Durangos are 4x4. Pretty limited use in a street rod. Gene
Re: Dakota and Magnum questions for rodders. [Re: poorboy] #1571797
02/05/14 02:19 AM
02/05/14 02:19 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
I believe all Durangos are 4x4. ...
Nope. But I used to think that also.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
