Need help on my 750 holley #1571693
01/31/14 06:49 PM
01/31/14 06:49 PM
Canada
Dons Dart Offline OP
Canada
Its a 3310-2 V S 750 on my mild 360 I have rebuilt it in the fall just me i know what i am doing but this has me stump,i am hopping maybe someone has ran in this problim and can help befor i chuck it.Here is what it is doing,flooding the rear secondaries its not coming out the boosters but it looks like it coming from the transfer slot, i have check to see if the float is sinking its not,when it running all is find i don't see any gas pouring out the boosters ,when i shut it down it stats to flood,in the rear only its done it from day one after the rebuilt any thoughts.I have check the needle and seat but nothing HELP.
Re: Need help on my 750 holley [Re: Dons Dart] #1571694
01/31/14 07:06 PM
01/31/14 07:06 PM
Andrewh Offline
Andrewh  Offline
where do you have the secondary' floats set to?
dribble out the sight hole, or must shake the car to get fuel out?
what pump do you have on it?
residual fuel pressure pushing it past the seat?
Is it level in the car?
I seem to recall someone having an intake that tipped it at an angle?
Re: Need help on my 750 holley [Re: Andrewh] #1571695
01/31/14 07:23 PM
01/31/14 07:23 PM
Canada
Canada
float is set to were i just push down on the fender and it dribbles out,have a stock pump,intake is the ld340 if it were the pump should it do the same to the front bowl.
Re: Need help on my 750 holley [Re: Dons Dart] #1571696
01/31/14 07:24 PM
01/31/14 07:24 PM
Andrewh Offline
Andrewh  Offline
would think that, but could be something slightly different about the back that lets it bleed off first.
not saying that is it, just asking questions.
Re: Need help on my 750 holley [Re: Andrewh] #1571697
01/31/14 07:40 PM
01/31/14 07:40 PM
Canada
Canada
I have no clue this is a first time for me.
Re: Need help on my 750 holley [Re: Dons Dart] #1571698
01/31/14 07:50 PM
01/31/14 07:50 PM
I'd install a new needle/seat assy. The current one might be defective even tho it was new
Re: Need help on my 750 holley [Re: Dons Dart] #1571699
01/31/14 08:27 PM
01/31/14 08:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Wrong gaskets, metering block /plate ????
Re: Need help on my 750 holley [Re: RapidRobert] #1571700
01/31/14 08:29 PM
01/31/14 08:29 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It almost sounds to me like a siphoning effect. Maybe an air bleed clogged in the secondary idle system and when you shut it off it keeps siphoning the fuel out. I have heard this before but never actually seen it. Ron
Re: Need help on my 750 holley [Re: Dons Dart] #1571701
01/31/14 08:43 PM
01/31/14 08:43 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Since you rebuilt it, I'd look at the base plate & gasket. They do warp & leak. I run a large flat file across both the main body & plate surface until even color change. Inspecting the gasket can sometimes lead to the bad area.
Re: Need help on my 750 holley [Re: 80fbody] #1571702
01/31/14 10:01 PM
01/31/14 10:01 PM
Canada
Canada
Thanks gang will try a few things.
Re: Need help on my 750 holley [Re: 383man] #1571703
02/02/14 04:14 PM
02/02/14 04:14 PM
Canada
Canada
I found 1 air bleed a little gumed up thanks.
Re: Need help on my 750 holley [Re: Dons Dart] #1571704
02/02/14 05:02 PM
02/02/14 05:02 PM
All good now or still searching
